Question about Motorola Mobility RAZR V3
Motorola L2 display problem
The display is very faint--barely readable in a darkened room. The phone works, keypad lights up, etc. I've tried putting a display from another L2 that I know works, but no difference--still the very faint screen. That is a display strip or are there other options to check. I do have another L2 for parts.
Thanks,
Steve
  • Steve Marsden Aug 21, 2008
    As mentioned, I replaced the LCD screen with one from another L2 that I know works. Same result, a dim/faint screen. So I know it's not the LCD screen. Thanks for trying.
  • shlnshon Dec 17, 2008
    I just bought my phone and I have got the same problem...the display is very faint...seems like as if the back light is off
My problem is dust is inducting in display give me best possible solution
Posted on Aug 21, 2008
    Brigadier General:
  • 7,752 Answers
You need to take the phone and have the LCD replaced
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
My Z3 got wet...
can you send me a code so i can unlock my phone
Apr 25, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Pairing Jabra BT135 with motorola L2
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Feb 11, 2008 | Motorola Mobility L2 Cellular Phone
Won't turn on
theres a problem with flash memory chip on the cellphones board, you need to hot air solder it, but if this didn't work the chip is damage and it needs to be replace
Dec 16, 2007 | Motorola Mobility L2 Cellular Phone
Motorola V3 Razr Keyboard will not light up
Are you getting sounds from the dial pad? It should default to momentary lighting, but it can be adjusted for longer time. It sounds faulty, did you purchase a refurb?
Oct 31, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Keypad now out
Most likely a battery problem, or the battery connections in the battery bay inside the phone. Try cleaning them etc.
Sep 08, 2007 | Motorola Mobility RAZR V3
Display turned off, but i can make and receive calls
If you take the battery out then with the battery out plug in the charger, this worked for me.
Jun 15, 2007 | Motorola Mobility RAZR V3
RAZr V3 Keypad lighting not working
Settings, Initial Setup,Backlight. Try this. Hope it works.
Nov 02, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
88 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
