Question about Averatec 3200 Notebook
Power plug problem
I would love to sent it back to get fixed but I have broken the tamper seals trying to unscrew and disasemble. I doubt they would fix it any way, what do you think ?
At one time Averatec was offering to repair this problem for free outside of the warrenty because of the fire risk and so many reports. The warrenty is only good for a year anyway unless you got some extended one. Averatec doesn't support there products as well as other companies. Contact them and see what they say.
When I had this problem I decided to fix it myself because if you send the laptop in they automatically format your hard drive and reinstall the os. I got a power supply board on ebay for fairly cheap and installed it. If you are afraid to take things apart you might not want to try this tho.
ON ebay some people sell the jack only which also requires you to solder it. If you find a ac power board the jack is installed on it already so you wont have to solder it.
** Look at the picture mine had a reinforcing strip wrapped around it to prevent the problem from happening again.
Posted on Jul 27, 2008
Same thing, can't open the case to get at the power plug.
Posted on Jul 23, 2008
Which brand of industrial seals do you use?
I use tydenbrooks for my company. My staff suggested me about it. It doesn't have much of bad points but sure do have plenty of good points. I love how it has wide range of industrial seals to choose from whether you like padlock or wire seals or electronic seals or plastic seals and many more. It can overcome high strength and has warranty as well.You can try this site Security Seals High Quality Tamper Evident Seals Bolt Seals Cable Seals...
Mar 27, 2014 | Global Industrial 00 5x10 Self Seal Kraft...
To clarify, the seat is stuck all the way back. I cannot hear the motor attempting to operate and a voltage check shows power at the switch and at the plug near the motor. I think it's the motor but I...
It definitely sounds like the motor. You need to disasemble the seat to get to the mounting bolts to remove the seat and get to the motor. Might be easier to just fix the handle and move the seat manually.
Aug 10, 2013 | Porsche 928 Cars & Trucks
When I plug my xbox controller(wired) into the 360, it keeps blinking over and over. I think it might be a shortage because it only works if you move the controller around. Is there any way to fix this?
The only way to fix a broken controller is by purchasing the Tamper Proof Screwdriver from Microsoft. You could also try removing the plastic from the wire and see if there is a broken connection. If you find one, solder it back together and use heat shrink tubing to put it back together. I hope this helps!
Dec 22, 2010 | Microsoft Xbox 360 Controller
REPLACED POWER JACK.POWER LIGHT COMES ON ,BATTERY CHARGES,BUT NO BIOS OR SCREEN ACTIVITY. ACER 9300
hello,
probably when the power jack was being changed, a connector cables was mistakenly tampered with,
therefore in order to fix this, try to unscrew the laptop, check all available cable that makes a connection. once you sight the cable that was tampered with, connect it back to its normal place, screw thelaptop back together then turn it on.
Jan 02, 2010 | Acer Aspire 9300-3716 Notebook
Warranty on pc
To whom it may concern,
Unfortunately you have tampered with the unit which has damaged the "tamper proof" seal. If these seals are broken all warranties are void and this is standard practice. If the seal was still intact then they would have to replace the failed component. The seals are used for people who try to update and change internal components and damage the machines. This protects the companies when unqualified personnel decide to tinker and then make a claim when they do damage. Unfortunately this also means that you also fall into this category and the company is no longer liable as the seal has been broken and they consider this to void the warranty for obvious reasons. Sorry I cannot offer any further assistance.
Jul 29, 2009 | Computers & Internet
My samsung model LN-S40510 40" LCD tv doesn't turn on...it just "clicks" as if were trying to turn on...and contines "clicking" every few seconds until I pull the cord from the...
I GOT 1 FOR 40.00 OTER DAY AND THE PEOPLE TAT HAD IT SAID A TECK TOLD THEM 900 TO FIX IT GL
I GET MINE TO WORK SOMETIMES. U HAVE TO HAVE PATENCE HERES WHAT I DID.
LEAVE IT OFF FOR A FEW MIN THEN PLUG IT IN AND DO NOT HIT THE POWER BUTTON LEAVE IT ON FOR A FEW MIN IF IT DONT COME REPEAT THE STEPS A FEW TIMES .
MINE WORKS AFTER THAT FOR A FEW HRS THINKING U COULD SELL IT BETTER THAT WAY .
Sep 08, 2008 | Televison & Video
Turns on and after a few minutes the image disapear
i think it's a problem in the power circulation so i think u may let someone who know more about the ps3 power see ur ps3
Aug 24, 2008 | Sony Playstation 3 (PS3) Console
How do I fix it myself?
Just pop the faceplate off and tlook at the silver Microsoft sticker. If it has been tampered or removed then it will not look completly silver, it will have little pieces of the silver removed from the sticker.
He4re is the site to get the detailed instructions and parts to do the job. www.llama.com
Good luck to you and happy gaming.
Aug 22, 2008 | Microsoft Xbox 360 Console
Averatec 3200 Notebook Logo
70 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
