1999 Jeep Grand Cherokee Logo
Posted on Jan 20, 2011
My 99 jeep grand cherokee limited isnt starting and the no key symble is on. The car wont start, and it keeps killing the battery, and the only thing is that the no key symble and the car not starting didnt pop up till today. I started the car yesterday but had to jump it yesterday, but i tried to jump it today and nothing happened. What do i do?
  • Steve Allison
    Steve Allison Jan 20, 2011
    " i tried to jump it today and nothing happened."
    Define? Does this mean the starter won't run or that the engine cranks but won't start?
    The drained battery could mean a failed alternator. These are basically AC generators and they have semiconductor diodes in them that convert the AC to DC for the system and charge voltage.
    If one fails (shorts) this will cause the battery to discharge through the failed part.
    You should have the alternator checked; this is done free at any chain auto parts store but you will have to get the vehicle or the alternator there first.
    If you remove the battery, always disconnect the negative (ground) cable before the positive to avoid shorting the battery to ground and damaging battery and tools.
marctflanaga
Level 1:
New Friend:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Jan 20, 2011
marctflanaga
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
1037
Points
10
Chrysler vehicles are very picky about the voltage. Most likely needs a new battery or alternator. Take it to get the battery and alt. tested.
I have a 1994 jeep grand cherokee limited 5.2L and I need to know where the alarm starter kill relay is located
we cant do that, no idea at all what that means.
no such thing, exists./
post symptoms first so the helper can be on same page.
alarm problem?
cant crank engine?
engine wont start.?
what?
I have a 99 jeep grand cherokee 4.7, the alarm went crazy and the wont start. guages dont budge and horn keeps honking and lights flashing. sentry key light is on in guage cluster any help
Sounds like you need to perform a relearn on the anti theft system, it's not recognizing the key if this happens with the key inserted. Might want to look online for a reset procedure for Jeep. GM has you keeping the key in the ignition in the on position for 10 minutes.
3helpful
I have a 95' Jeep Grand Cherokee Limited with a
Are you check your previoud questions: check_engine_error
Keep us updated.
Car alarm wouldnt shut off ,disconnected the battery,lights still flashing wont start.Is their a kill switch somewhere?
alarms are funny things get a electritian to have a look and possibly put in a killswitch for you if there isnt one
My 1995 Jeep grand Cherokee wont start.
when your car does not start it could be a number of things starting with your power system check your battery conections alternator output and battery voltage they should all read 12.6 volts
2000 Jeep Grand cherokee Laredo wont start. Engine turn over . No noise from fuel pump with ignition on. Replaced fuel pump and filter.Turn ignition on- pump did not run.Jumped the fuel pump at the pump...
sounds alot the the pcm it controls the fuel pump and ign system but the anti theft would keep it from starting because the key has a transponder in it programmed for that vehicle and that would kill all ign if triggered
1helpful
2answers
1993 JEEP GRAND CHEROKEE LIMITED W/ FACTORY SECURITY SYSTEM. SYSTEM STAYS ON WONT CUT OFF AND IT WONT START.
93 jeep grand cherokee limited only have ignition key and changed battery and now security lights and headlights wont quit flashing help!
1helpful
2answers
1996 jeep grand cherokee limited won't start alarm keep flashing
try the 15 amp fuse under the hood by the battery if its blown put in a 20.
turn on the key and wait for all the ligth to go out then try it if it dosnt start the first time do it a 2nd same thing
hope it helps
Dome light not turning off now wont start???
Sounds like you activated the factory alarm.
Hook up the baterry and unlock the drivers door with the key in the door cylinder.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
