1.
Open Display in Control Panel.
2.
On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3.
When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4.
Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
If you cannot set it any higher than 1024x768 and you have already installed the video drivers, that is as high as it can go for your hardware.
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
I had the same problem. To fix that change the resolution to 1024x768 if your laptop resolution is set to high it will come out like you said. just have to change it back and forth to play the game.
I had the exact same problem and I searched everywhere on the net to try and find a problem with no avail. Then I thought of something and it fixed it!
Change your screen resolution to 1024x768
That's what fixed mine.
You can go higher. The maximum size I can get mine to before it gets distorted is 1360x768.
