Question about Microsoft Office Professional 2007 Full Version for PC
Macro Need to know how to create a macro to set all the forms on a excel sheet to a default value. Also have created a macro to paste values from specific cells to a different sheet. need to know how to instruct the macro to automatically paste the values in a different row every time
    Problem Solver:
  • 18 Answers
Hi alwinkumar
You can set a default value in most form items under the properties of that item. Look for "value". You can also do this in code, by setting up a sub routine to set/reset the values on your form. Then just run the sub routine before you open or enter the form.
Private Sub resetForm()
'formname.itemname = value
UserForm1.Label1 = "Hello World"
End Sub
For the second one you have a couple of options, you can find the bottom on the data and store the row index in a variable, use a loop to find the next empty cell in a row, and store the value or you can use the current region method to select all the cells with data continously touching the selected range. Example below
numberOfRows = Sheet1.Range("A1").CurrentRegion.Rows.Count
Posted on Jul 19, 2008
Macro help in Excel
go google and type in--- user manual for excel---
there is a pdf version about 900 pages long that explains everything you want to know and do in excel
Mar 27, 2017 | Microsoft Office Excel 2003 for PC
=spellnumber is not working in my excel sheet
Spellnumber is not actually a pre-defined macro in Excel. Microsoft has an excellent guide on how to create this function here: http://support.microsoft.com/kb/213360
Mar 01, 2011 | Computers & Internet
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
Step by step instructions on how to create a macro, create form f
You can create a macro by using the macro recorder to record a sequence of actions, or you can create a macro from scratch by entering Visual Basic for Applications code in the Visual Basic Editor.
Open a new document.
From the Tools menu, choose Customize.
Click the Commands tab and then scroll down in the Categories box and select Macros. You’ll see the names of any macros you've created in the Commands box on the right-hand side.
Click, hold, and drag your macro onto any toolbar and release, as shown in Figure D. A button with the name of the macro will appear on the toolbar.
May 25, 2010 | Microsoft Office Word 2007 Full Version...
How to create macro button in microsoft excel 2007 because
well follow the steps below to get your job done:
To create an option button in Microsoft Office Excel 2007, make sure that you add Option Button (form control) to the Quick Access Toolbar. To do this, follow these steps:
  1. Click the Microsoft Office Button, and then click Excel Options.
  2. Click the Customize category, select All Commands in the Choose commands from list, select Option Button (form control), and then click OK.
To create an option button and to assign a macro to it, follow these steps:
  1. In Excel 2003 and in earlier versions of Excel, click Option Button on the Forms toolbar, and then draw the outline of the button on the sheet.
    In Excel 2007, click Option Button (form control) on the Quick Access Toolbar, and then draw the outline of the button on the sheet.
  2. Select any cell in the worksheet.
  3. In versions of Excel that are for Microsoft Windows, right-click the option button, and then click Assign Macro.
    In versions of Excel that are for Macintosh, press COMMAND while you click or press CTRL while you click, depending on your operating system version. Then, click Assign Macro.
  4. In the Assign Macro dialog box, click the name of the macro that you want to assign to the option button, and then click OK.
When you click the option button, the macro will run.
good luck ...:-)
Apr 08, 2010 | Microsoft Office Excel 2007
Macro code for copying a range of cells from one Excell w/sheet t
You did not respond to my claification request. Here is some code that might help, it copies a selection of cells going down until an emty cell is found and across until an emty cell is found. This is form an earlier version of office but should comeclose to woring in 2007.
Sub copyrange()
' copyrange Macro
' Macro written by Royal 11/22/2008.
'save the return values
wksname = ActiveSheet.Name
returncell = ActiveCell.Address
searchfor = ActiveCell.Value
'go to first worksheet and find entered value (note this is a value serach)
Worksheets(1).Activate
findfor = "A1"
On Error Resume Next
findfor = Cells.Find(What:=searchfor, After:=ActiveCell, LookIn:=xlValues, LookAt:= _
xlWhole, SearchOrder:=xlByColumns, SearchDirection:=xlNext, MatchCase:= _
False).Address
If findfor = "A1" Then
erwks = ActiveSheet.Name
Sheets(wksname).Activate
er = MsgBox("Search item not found on Worksheet" + erwks, , "Search Error")
Exit Sub
Else
findfor.Activate
End If
Cells.FindNext(After:=ActiveCell).Activate
'save this address and start searching for copy area boundaries
begcell = ActiveCell.Address
begcl = ActiveCell.Cells.Column
begri = ActiveCell.Cells.Row
'search amaximum of 1000 rows and 676 columns
endri = begri + 1000
endcl = 26 * 26
maxrow = 0
maxcol = 0
For col = Cells.Column To endcl
If Cells(begri, col) = "" Then
maxcol = col
col = endcl
ri = endri
Else
ri = begri
End If
For ri = ri To (Cells.Row + 1000)
If Cells(ri, col) = "" Then
If ri > maxrow Then
maxrow = ri
End If
ri = endri
End If
Next ri
Next col
maxrow = maxrow - 1
maxcol = maxcol - 1
'copy the selected area
endcell = Cells(maxrow, maxcol).Address
crnge = begcell & ":" & endcell
Range(crnge).Select
Selection.Copy
'go back and paste it in
Range(returncell).Select
' use this if yo want to paste formulas etc.
'ActiveSheet.Paste
' use this code if you want to paste values instead of formulas etc.
Selection.PasteSpecial Paste:=xlValues, Operation:=xlNone, SkipBlanks:= _
False, Transpose:=False
Nov 20, 2008 | Computers & Internet
Excel formula creation
= (a3) minus (b3) won't do it for you?
Sep 05, 2008 | Excel (SS8SATAS5128400R)
One problem in the application of excel sheet
I can make out that
You are speaking about creating a macro to take data from one constant updated cell and to put that data into another cell or form sheet.
You will need to get precise help from a programmer on this.
If you want to see a little on macros just open a sheet and checkout the help section on macros.
Some macros can take many hours to write and test.Some make take months.
hope this helps.
Jan 30, 2008 | Microsoft Windows XP Home Edition
Need to Know fully info about Macros
Macro is a simple way to automate tasks in Microsoft Office programs. It allows advanced users to program or create their own commands in Office, thereby automating tasks. For example, a user might want to create a table with four values already in them. The user could create one, and then copy it, and paste it. However, when you restart your computer, that data is lost. Unless you open the old document and copy the table, you'll have to start all over again. Macros helps you do your tasks. By recording the table creation to a macro, creating the same table over and over is just a simple macro away.
Sep 26, 2007 | Microsoft Office Standard for PC
Microsoft Office Professional 2007 Full Version for PC Logo
182 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
