Question about InFocus ScreenPlay 4805 Multimedia Projector
4805 shadow left side of the screen has a vertical shadow about 4 to 6 inches wide.
  • dragon8w Jul 25, 2008
    I have the same problem with 3, X3 projectors. IT has a shadow on the side of the screen. two of them are the same 4 to 6 inches as mentioned earlier. The other one has almost 3/4th of the screen in shadow.
    Novelist:
    Scholar:
  • 149 Answers
That is typically called Ghosting but can also be called eclipse. Is the shadow a dark shadow or is it light?
It is hard to remove something such as this because it was a generation issue at one point that the manufacturer eventually had fixed entirely with newer chips with more advanced technology to it.
Can you do me a favor and post a picture on a host website that allows you to let others view your pic's then post the url on here so I can get an idea of what it looks like. It helps for me to see it since some times it can be mis-diagnosed but just talking about it.
Also, does it look like pixels might be out instead of a shadow--possibly?
Thank you for time and your request. Let me know if you have any further questions.
Posted on Oct 27, 2008
The big fat lens that is next to the mirror is unaligned. i dont know how to fix it though
Posted on Aug 28, 2008
I had the same problem just 99 hours after changing the lamp for the first time. The problem you describe is most likely the light tunnel that is cracked. I wasn't able to buy a new one on my own, I had to turn it in for repair. The light tunnel is only a couple of mirrors that the light travels between.
Posted on Aug 02, 2008
LG MODEL 55LM4600 THAT HAS A VERTICAL SHADOW ON THE RIGHT SIDE OF SCREEN ABOUT 3 OR 4 INCHES WIDE. hAVE YOU HAD THIS BEFORE?
Line fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 03, 2015 | LG Televison & Video
Dark haze left side of screen about 4 to 6 inches wide only in the wider screens not in the native
Its a Light Tunnel failure. Go to www.avsforums.com and search for 4805 Light Tunnel. There are instructions to open the PJ and repair the Tunnel. Also, I posted a DIY replacement option in lieu of fixing the very fragile tunnel.
http://www.avsforum.com/avs-vb/showthread.php?t=1304694
Jan 02, 2011 | InFocus ScreenPlay 4805 Multimedia...
I have a 37in. vizio flat screen. It has a black shadow in the left center of the screen. It's there at all times.It's about 7in.x 3/4in.it runs vertical.any ideas?
wish the news was better for you, the convergence chip or the color engine has faulted and burned the screen This will be an expensive repair unless it has extended warranty
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Vizio L37 Television
Optoma RD-50 DLP has dark vertical shadow on right side of screen
turning off the main can be very harmful to rear projectors if you dont wait for the cooling off period, for instance when you turn off the tv from the remote, the fans inside are still on in order to dissipate the heat given out by the lamp. as a result some of the lens inside the engine may have burns-in caused by excess of heat.thus leading to shadows on the screen.
hope this helps
please rate me!
Mar 19, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Samsung dlp tv
Yes, it could. There is a light pipe in the light path that could now be broken from the bumping or it could just be out of line from the bumping. Another problem could be the mirrors in the projection path could just need adjusted by the 3 screws that are beside the mirrors. This may also happen when bumped.
Mar 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Lg 37 inch lcd has a dark shadow vertical line down left side of screen about 1cm wide and does not seem to go right to the top or bottom and is slightly wavey
reseat the LVDS cable inside the set. this is the multi wired connector that connects the main board to the panel. if that doesn;t solve your problem replace the main board. if you turn off the set and you can still see it in the screen it is the panel.
Feb 14, 2008 | Televison & Video
Shadow on right side of screen
check the connector of DMD module. Service all projector and reinstall.
Viren
Nov 18, 2007 | InFocus ScreenPlay 4805 Multimedia...
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
InFocus ScreenPlay 4805 Multimedia Projector Logo
178 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
