No video I have a intel d845pt motherboard I have put in 2 known good video cards and i do not get any video it just put the monitor to sleep.
  • Dean Gammon Sr.
    Dean Gammon Sr. Aug 15, 2008
    I have a P4VMM2 motherboard,/w/ Austin model:DR-B300ATX power supply.
    When I turn on my computer (after several attemtps) I get no video.
    My computer comes on then right back off(after several attempts,it does stay on).Don't know why?
  • 4 Answers
Connect your monitor cable to the graphics card output.
Posted on Jul 16, 2008
I am having trouble figuring out the control panel jumpers
Hi, here is a few pictures of controlpanel connections.
Hope this will help you.
Apr 11, 2011 | Intel Desktop Board D845PT Motherboard
USB 2.0 on Intel D845PT Motherboard
HI,
Yes, that board is only a 1.1 USB port. USB 2.0 can easily be added to a computer using a USB 2.0 PCI card. These cards are relatively cheap and they can be found in almost any computer store. You can even find USB 2.0 PCI cards at Walmart. The cards will typically have 3 - 5 ports on them. These ports are setup so that you will have to plug your USB devices into the back of the computer.
Good Luck
Mark
Dec 28, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
USB 2.0 on D845PT
Hi Again,
I guess you posted your question twice, but just in case, here's the same solution:
Good Luck
Mark
Motherboard Inquiry
They don't make motherboards with agp anymore. Your only shot would be on ebay. Your motherboard will only support cpu's that have a 400 front side bus. And will only support a cpu up to 2.0 mhz. And they don't make 478 socket cpu's anymore either. Looked on new egg only found 3.0 with a 800 front side bus. Here's everything you need to know about your motherboard. http://download.intel.com/support/motherboards/desktop/d845pt/a7585201.pdf
Aug 05, 2009 | Intel Computers & Internet
In-built video card not working. how do i switch if off and use another video card via PCI slot?
you can disable from bios
is likely onboard vga
But if you plug in a PCI video card the computer will use that video card
Jul 09, 2009 | Intel Motherboard
Need original bios
you should enter your motherboard manufacture website and dawanload new version
Jan 12, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
Bios hangs
Reseat all cards in system, including the RAM. If it still does not boot try removing one stick of ram at a time to see if it boots. As well as removing extra cards.
Jan 05, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
Monitor not on but menu light are blinking
Hi there, i assume you switch on the monitor but there's no display. Is the monitor working before this? If what i assume is right, you should check the connection between the monitor and the cpu. If that doesn't solve the problem, then you should check the vga card. Maybe the pci slot/vga port is damage. If that the problem, you should change another display card.
Dec 20, 2008 | Computers & Internet
No video
Try to check the light on the monitor. If it is amber, then check the video cable both from the back of the monitor and the tower. Try a known-good monitor. Check the diagnostic LEDS of the tower. There are four of them in the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem. If you have a solid green light on the tower, no beeps heard and no video, check the LEDS. If you get 2-4 light, a possible graphics card failure has occurred. If the computer has an external graphics card, open the tower, remove the card and put it back in. If still persist, try a known-good card. If it still does not resolve the problem, try reseating the memory cards. Remove and put it back in. If still no go. Then it's a motherboard problem.
Sep 16, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
426 people viewed this question
David Payne
David Payne
