Question about Averatec 3200 Notebook
Averatec 3200 power connector problem
How did get laptop disassembled ?  I took all the screws out some of the top assembly is loose but wont come apart ?
Same thing. How do you get the thing opened?
Posted on Jul 23, 2008
My averatec laptop will only power on to a black screen but it still sounds like its booting
1) Laptop on use a flashlight, and shine it at the LCD screen. Shine at various angles.
Do you see faint images?
2) You can also plug in a VGA monitor to the back of the laptop, (Laptop OFF, monitor off), and toggle over.
(It can be a VGA monitor that looks like a small TV {CRT}, or an LCD flat screen that has a VGA cable attached)
Plug the VGA monitor's cable into the blue VGA port on the left side, of the Avertec 3200 Notebook PC.
(Example of VGA connectors,
http://en.wikipedia.org/wiki/VGA_connector
Turn the VGA monitor on. Give it time to 'come to life'.
Turn the laptop on.
Are there graphics on the external monitor? If not press, and hold down on the Fn key, (Blue Fn next to the CTRL key), then tap the F2 key.
(The F2 key is the toggle over key for an external monitor. You can use the laptops LCD screen, or it's screen, and an external monitor)
Graphics show on the external monitor? Your graphics chip is good.
Problem is with the screen Inverter, or the Backlight.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert the electricity from the laptop, for the LCD screen, and the Backlight.
90 percent of the time the fault is the screen Inverter.
The Display Assembly essentially is;
1) Top cover of the laptop. (Display Cover)
2) LCD screen
3) Display Bezel. (Thin plastic frame in front of the LCD screen, and surrounds the LCD screen)
4) Inverter
5) Backlight
6) LCD screen frame
With the Display Bezel removed, the screen Inverter should be at the bottom/front.
This is an example of a screen Inverter for an Averatec 3200 from a quick search,
http://www.laptopaid.com/averatec-3200-lcd-inverter-board-76-030105-02-tested-1629.html
I haven't worked on an Averatec 3200 Notebook PC before. I have worked on 100's of other laptops.
The sequence for removing the Display Bezel follows a pretty standard approach.
Looking at the Display Bezel I see four screw covers. (I'm looking at a PDF Users Guide)
One at the top Right corner, one at the top Left corner, one at the bottom Left corner, and one at the bottom Right corner.
These screw covers made of a rubber-like material. (Synthetic rubber) They are slightly rounded on the top. They have a type of rubber cement that holds them in place.
I use a computer pick to gently pry them off. If you carefully pry each screw cover off, and set them down sticky side up, (Screw side), you can usually reuse them again.
Screw covers (4) removed, use a Philips head screwdriver, and remove all 4 screws.
The Display Bezel will still be held in place. It has plastic tabs on the outside edges that snap into the Display Cover. (Top cover of laptop)
A fingertip is used on the INSIDE edge of the Display Bezel, next to the LCD screen.
(WATCH your fingernails against the LCD screen)
The fingertip raises the Middle/Inside edge of the Display Bezel, just slightly.
Now use another fingertip on the opposite side. Raise the Middle/Inside edge.
The Display bezel should start 'popping' out. (As the plastic tabs release they make a popping, or snapping sound)
To illustrate this technique further,
http://www.insidemylaptop.com/replace-damaged-lcd-screen-dell-latitude-e5400-e5500-laptop/
http://www.insidemylaptop.com/replace-lcd-screen-inverter-dell-inspiron-1525-laptop/
(One more, to show you where I believe the screen Inverter is for the Averatec 3200 Notebook PC, and what an average screen Inverter circuit board looks like,
http://www.insidemylaptop.com/remove-screen-inverter-dell-studio-1737-1735-laptops/
When the Display Bezel is loose, you slide it to one side a little to ease it around, and off, of the cover latch.
The cable connectors going to the screen Inverter are shaped differently from each other, so that when you go to reinstall them, there is no chance of mixing them up.
With the tools you have available, I would replace the screen Inverter ($7 plus shipping), and see if this repairs the problem.
If not the problem is the Backlight. Most of the time you have to buy the LCD screen, as the Backlight is an integral part of it, and should be replaced by a professional.
[ An LCD screen is composed of layers. The layers are held together in the correct alignment by the LCD screen frame.
This alignment MUST be aligned as it was from the factory.
This gives you an example of replacing a Backlight,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Make a mistake here, and you can throw your LCD screen in the trash ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 21, 2011 | Averatec 3200 Notebook
Averatec 3200 problem charging battery connection to adapter loose or wire inside adapter problem?
Check if the charger has voltage which is 19 volts typically. If it does the charger is good. So that means the problem is in the laptop. Many times where you plug it in gets bad solder connection or the connector inside gets worn from plugging it in and out improperly. They should be plugged in straight and carefully. Then pulled out straight as well to prevent damage.
Jun 26, 2010 | Averatec 3200 Notebook
Averatec 2300 series
Does it feel loose where the power cord plugs in? Did this happen overnight or were there more symptoms?
May 05, 2010 | Averatec 3200 Notebook
Can not take a part my averatec 6200
There is no such manual as this is a dangerous self fix. Look for a generic OEM replacement on Ebay.
Apr 10, 2009 | Averatec 6200 Notebook
My Averatec 3200 turns of randomly...
Check the CPU and Fan/Heatsink assembly. I have a pretty good feeling that the CPU is heating up too much and is not being cooled properly. There may be lint or dust clogged in the fan. You can get access to this pretty easy by removing a few screws on the bottom panel that houses the CPU/fan.
Feb 20, 2009 | Averatec 3200 Notebook
Spilled liquid
It sounds like it shorted out the keyboard.
You will have to contact Averatec about purchasing a replacement .
Changing them is fairly simple.
Pop out the old one, unplug the wire connector, plug in the new one, and pop it down in place.
Jul 31, 2008 | Averatec 3200 Notebook
Change hard drive
You will have to disassemble the laptop a bit to swap hard drives. Check this link: http://www.flickr.com/photos/dnhoshor/sets/72157602004333279/show/
it shows a photo disassembly that was made to repair the power jack bu you will see the hard drive in image # 10
hope this helps
Apr 23, 2008 | Averatec 3200 Notebook
My jack is bad
This is a photo guide for your exact problem Not exactly easy but if you or a friend is skilled at disassembly/soldering... the part is about $10.00 on eBay just look for averatec 3200 dc jack. Needless to say if you do not feel comfortable doing this sort of thing take it to a local repair shop
Apr 18, 2008 | Averatec 3200 Notebook
Disassemblyan Averatec 7100 how to,...
start popin' screws out and popin the case apart
Dec 17, 2007 | Averatec 7171000100 Keyboard
Plug in is broke
you cant buy a new one..........
Oct 07, 2007 | Averatec 3200 Notebook
Averatec 3200 Notebook Logo
98 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
