Washer will fill up and agitate but will not go any further.
  • 481 Answers
Fist thing to check is the lid switch. make sure it is making a clicking sound when you open and close the lid. if not then it may need to be replaced.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 16, 2008
  • Mike Durland
    Mike Durland Jul 17, 2008
    • none of my free suggestions have helped you at all?
    •  if you feel the issue with the machine is something else let me know, i will try to help you figure it out.
    • a little more info would help
    Mike
Kenmore 417.97922701 washer tub will spin but will not agitate
Disconnect power to the unit.
Does the agitator move freely in both directions by hand?
Could be your agitator coupler needs to be replace
Also need to verify the lid switch and pressure switch are working properly. Let me know if you need further assistance
Nov 10, 2014 | Washing Machines
My washer will fill up and then skip the wash cycle, it will then drain rinse and then spins it out, any ideas?
Top load washer check the agitator dogs located inside the agititator here is a video if you have a top load washer on how to change the agitator dogs as well http://www.youtube.com/watch?v=yRA08dwufUk if you have a front load washer message me back for further diagnosis. Thanks Rick
Jul 09, 2011 | Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Washer does not seem to change cycles. Fills and agitates fine, but does not seem to go further than the first cycle.Suspect timer issue.
    Good day,
    If it fills and agitates and gets thru the first cycle, but won't pump out and spin, then it would be a bad lid switch. Check the following clip for more info.
    http://www.youtube.com/watch?v=fC8SY3cU1Yc
    Nov 06, 2010 | Whirlpool Washing Machines
    Won't finish the final spin
    Post further comments for more information ....
    Good Luck!!
    Thanks
    Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Kenmore 24732 will fill and drain but will not agitate or spin
    HI, Even tho it drains ok, does it spin? If it doesn't spin or agitate, it could be the coupler that attachec the transmission to the motor.The agitator is ok, it is designed to work that way. Please let me know if I can assist you further.
    Thanks
    Vic
    May 17, 2009 | Kenmore 24732 Top Load Washer
    Stuck in spin
    Hi!
    If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
    It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
    Do rate the solution as FixYa and revert for further clarification.
    Thanks
    Rylee
    Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer will not agitate or spin
    HI,
    you can view this site to have some ideas about your agitator problem.
    http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
    any further question let me know.
    thanks,
    Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
    Agitating to many times
    Have you verified that you do not have a siphoning condition? The following link explains:
    http://www.fixya.com/support/r587481-prevent_washer_siphoning
    Please double check the installation and placement of your drain hose. If the top of the standpipe is sealed off, or if the drain hose is shoved too far down into the standpipe, this can create a vacuum. This can cause the washer to constantly siphon out of the wash tub on the fill cycle and the washer will continue to fill (as needed) to maintain the water level. In other words, what may appear to be a significant problem, can be something as simple as a simple placement issue with the drain hose.
    If you have further questions, please let me know. If the diagnosis is not correct, please post back and also let me know, so that I may be able to assist you further. I hope this helps you.
    Jan 19, 2009 | Frigidaire GLWS1649A Top Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
