My auto dose not work - Audio Players & Recorders
  • 2,071 Answers
Hi! Flipper Do this maybe of help. Turn the power off. Wait about 10 seconds, then power up again. Get close to the reciever and listen for a click-not from the speakers,from the recievers itself.If you hear a click, you can assume that the power supply is ok for that circuit.This does'nt eliminate the power supply problem but it will do for now.You would have to check both the positive and negative voltages from the power supply to see if both are present or if one or both are missing. This would be dc voltages and the positive voltage must be equal to the negative voltage ,if one is higher than the other, the regulator transistors in the power supply maybe defective. The transformer can be checked for AC voltage before the power supply.You know that the secondary is good because the dial lights. For this kind of problems you better change the regulator transistors with desame number.
If i have helped,please click fixya.It is the only way i get paid for my work also,please consider leaving feedback....
Posted on Jul 16, 2008
No all i want is a new master cylinder for my clutch the one on the car dose not work good
answered before fixya doesnt sell auto parts or any product --look online or go to auto parts store
Oct 05, 2016 | Cars & Trucks
I have a 2005 Chevy express 2500. The radiator has two small lines on it. Where dose the top line go and where dose the bottom one go?
2 steel lines
if it is an auto they are the transmission oil lines that connect to the oil cooler in the tank of the radiator
Jan 26, 2016 | Cars & Trucks
2010 landrover smaller SUV LT rear window auto down works but auto up dose not repl. The regulator. Tried to rest hold down and hold up 7 sce. Still doesn't work
Most likely the BCM is the problem since the same circuit is used for both the up and down directions, only difference is the BCM reverses the current flow to the window motor, but its done internally byt the BCM.
Feb 27, 2015 | Cars & Trucks
Friedrich CP24F30 money saver mode not working
Money saver mode dose not regulate room temperature. All that mode dose cycle fan on and off with the thermostat if in the yes position then fan cuts on and off with the call for cool. if in the no position than fan runs all the time even when cool is not needed. that switch is like the auto/on on a thermostat for central air. the thermostat is what regulates temp in room.
Jul 01, 2014 | Friedrich Heating & Cooling
Guage Cluster Dose not work
Have the CPU program reset by using a code reader . When the battery is removed the CVPU program becomes corrupted . As to the radio you will need the radio security code to re set it.
Mar 01, 2014 | 1997 Chevrolet Venture
Starter clicks but wont start
If your starter clicks but dose not work, then you will need to have your starter checked. It sounds like your silinoid has stopped working. You can either take your starter off and have it checked at Auto Zone or which ever Auto store or maintenance shop you prefer. It does sound like you have a faulty silinoid. Hopes this help.
Jul 25, 2012 | Motorcycles
Auto dry not working
I hope this video will help.
 http://www.youtube.com/watch?v=rQV-z4f7fvA
Also Need a good meter to check all of this.
Was  this helpful?
Mar 30, 2009 | Kenmore 73932 Gas Dryer
Disc aint working for me
Ive noticed that, too. Run the disc manually. For me it works good.
Sep 26, 2007 | Brother Multi-Function Center MFC-240C...
27 people viewed this question
 Grubhead
Grubhead
