Ovens Logo
Posted on Jan 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I ran the self cleaning oven and now it is locked and I cant turn it on?
Anonymous
Level 3:
  • Magic Chef Master 43,501 Answers
  • Posted on Jan 20, 2011
Anonymous
Magic Chef Master
Level 3:
Answers
43501
Questions
0
Helped
10844419
Points
101584
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    1helpful
    I ran the self-cleaning and the door will not open.
    Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
    or
    Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
    If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
    Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
    4helpful
    3answers
    I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
    or
    1helpful
    F90 code flashing and i cant reset it
    F90 Maximum oven door unlock time exceeded.
    F91 Maximum oven door unlock attempts exceeded.
    F92 Maximum oven door open time exceeded.
    F93 Maximum oven door lock time exceeded.
    F94 Maximum oven door lock attempts exceeded.
    1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
    2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
    3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
    4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
    5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
    6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
    7. If all situations above do not solve problem, replace EOC.
    F90 is a door lock code, Try this...
    unplug the range.
    wait 1 minute.
    turn the range back on,
    then while holding in on the oven door.
    start another self clean.
    wait 2 minutes.
    then cancel the self clean.
    do not release the door until the door lock light goes out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
    2helpful
    Lock light on frigdaire self cleaning oven
    OK, this is not a good situation here. your Electronic Oven Control board is damaged. the logic sectors are faulty. The F-1 represents a major EOC failuer and, you will need to replace your EOC(clock) asap, if possible.
    1helpful
    How much time to leave on self cleaning...clock does no work
    Depending on the condition of the oven, it could take up to 4 hours.
    I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
    A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
    Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
    2answers
    Self cleaning won't shut off
    that is because it needs to cool down before the oven will unlock.There should be a timer running and when it gets to "zero" it should unlock.
    1helpful
    Cant unlock self clean oven door
    Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
    Oven door won't open after self cleaning
    it hapen to me i activated the self cleaning gently hit the top of door and turn the self cleaner off the latch came off was able to use the oven did not used cleaner again clean it manuelly did not whant to spend the money
    Oven wont come on
    the oven door lock assembly has locked its self in to clean you can find the door lock assembly at the top of the oven where the door shuts sometimes if you push on the locking hook this will solve the problem
    Top Magic Chef Ovens Experts
    ZJ Limited
    ZJ Limited
    vince
    Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
