Question about Car Audio & Video
Protection light coming on and amp cutting off
My amp works fine until i turn up the volume then it cuts off and the protection circuit light comes on. i have double checked and everything is hooked up properly. can the size of the power and ground wire have anything to do with the problem
  • ghjelsin Aug 07, 2008
    As soon as the amp gets power the protect light comes on and shuts down the amp. I have checked the fusesand I have checked the wiring. If the amp is getting too much power what are some other things I can check. Could this also be a problem with the deck itself?
  • claudermilk Oct 06, 2008
    Similar problem. On powering up, the protect light comes on and shuts off the amp. This is only on the 2050 for the sub--the 4065 runs fine. The system did run correctly for a while, then this started. I tried unplugging the speaker, no change; also the source, then it doesn't power up at all. Could it be a power or speaker wire gone bad?
Yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Posted on Jul 18, 2008
I HAVE KICKER 1000 WATT AMP, FOR SOLOBARIC SUB, AND AMP PWR LIGHT STAYS ON, BUT YOU CAN HEAR THE AUTO PROTECT KICK ON AND OFF, ANY VOLUME LEVEL. I GET A FEW "BOOM BOOMS", THEN IT CUTS OUT, AND...
Sounds like a bad ground connection, be sure to ground the amplifier to the chassis of the vehicle. If need be sand the paint don't to bare metal to ensure that you are getting a solid ground.
Aug 12, 2017 | Kicker KX400.2 Car Audio Amplifier
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
I have a JBL1004 amp in my ski boat. I killed the battery listening to the stereo and caused the battery to lose a cell and drop to 10 volts. The stereo cut out as one would expect. I have replaced the...
if the protect light comes on then you might not have enough voltage running to the amp so you would need to add a second battery just for that amp.
Jul 26, 2010 | JBL GTO1004 Car Amp
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Yamaha p4500 protect lights do not go off at power up
You only normally get that when the Volume over peaks, and the amp will automatically cut out to prevent it fron blowing the whole P.A up.
If you know it was working fine before the wires were twisted together, then best try undoing what was done, and making sure that the Amp's Volume is turned down to minimum.
Dec 02, 2008 | Yamaha P4500 Power Amplifier 2-Channel
Sonamp 260 cuts out
Normally this denotes a protect condition. Remove the speaker wires from the back of the amp and see if the green light stays on. If this fixes the problem, then there is a short circuit in your wires, speaker level volume control or speakers. The amp sees the short and goes into protect. After a couple seconds it closes the connection again and if the short is still present it goes back into protect.
Aug 03, 2008 | Sonance Sonamp 260 MKII 2-Channel...
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
Jl audio e6450 cuts out above mid-volume
take a look at the power, ground and remote wires. the power and ground should be a minimum 6awg in wire size, and the remote wire at least 12awg. it sounds like your drawing a lot of power,so smaller wires usually mean more heat...the amp will turn off into protectedmode if it gets hot or is used for along period of time,so on any road trip make sure if isnt msothered by sleeping bags,coolers etc...just like any major electronic component, it needs room to col off.
Sep 02, 2007 | Jl Audio E6450 Car Audio Amplifier
Car Audio & Video Logo
850 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
