Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
Toshiba 52hm84 DMD board
No one seems to know how to find a DMD Board for a Toshiba 52HM84 HDTV. I am under the impression it is a set of boards/chips but I can't find anyone to answer my questions. Even Toshiba. Does anyone know what parts (number would be helpful too) make up the DMD board for this product.
Thanks,
wits-end
  • jholm7 Jul 16, 2008
    Here is a link to my TVs problem:
    http://www.fixya.com/support/t759015-whi...
  •  adriano nascimento
    adriano nascimento Sep 14, 2012
    mr jholm7 gooood...tank you
Go to Shopjimmy.com to buy the DMD chip $216.00 I am buying mine and will replace it.
When I am done I will let u all know how it went
D Fishintv guy retired
Posted on Jan 20, 2012
  • Toshiba Master
  • 8,617 Answers
The DMD panel is made up of individual " Digital Micromirror devices" (DMD) one mirror per pixel. They are HD2+ DMDs which are the 4th generation DMDs. I dont have a part number but what is your set doing for symptoms? DMDs are basically small mirrors mounted on hinges that react to the digital inpulses so the signal can aim the mirrors percisely. Toshiba should have a replacement panel available. Let me know if I can assist you further.
Posted on Jul 16, 2008
I have a toshiba 52hm84 green light blinks 10 but the red lights steady i change the lamp still same.no picture
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
Dec 31, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
Toshiba 52HM84 Manual Download
Toshiba 52HM84 DLP Projection HDTV Manual Download
Have you misplaced your Toshiba 52HM84 DLP Projection HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 52HM84 DLP Projection HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 52HM84 DLP Projection HDTV instructions.
I hope that helps.
_______________________________________________
Toshiba 52HM84 Service Manual Download
on May 14, 2010 | Televison & Video
Tip
Toshiba 52HM84 DLP Projection HDTV Service Manual Download
Have you misplaced your Toshiba 52HM84 DLP Projection HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 52HM84 DLP Projection HDTV Service Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 52HM84 DLP Projection HDTV Service instructions.
I hope that helps.
on May 13, 2010 | Televison & Video
Resetting lamp hour monitor
It's in the menu under setup or setting.
Mar 24, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Jan 18, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
I hope that helps.
on May 13, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
I hope that helps.
52hm84 Lamp not working sometimes
Its the ballast. I don't know your skill level so I can't say wether you can or not. It may no longer be available. As of 3 month ago the light engines needed to be removed and sent to Toshiba to be rebuilt. The ballast is on the light engine assy behind the lamp.
Dec 01, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
52HM84 previous issue and recent question links
I am checking with some of my sources at my other job to see if there is a source for the DMD panels.We are running an auto submission program to their distributors.
Jul 16, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
923 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
