How to check automatic transmition fluid in my 2000 cavaliar.
I cannot find a dip stick.
  • 2,237 Answers
Engine compartment
Posted on Dec 23, 2009
How many quarts of trans fluid does a 2000 ford explorer v6 need
Did you check your trans dip stick? The tranny dip stick usually has a quart low mark. If this is a manual tranny, that is different, you didn't specify automatic or manual tranny?
{Automatic tranny, the spec is for dry fill, only. 10--12.7 quarts . Dry fill means not a drop of tranny fluid in the vehicle.}
You have to check proper fluid level, that is your responsibility. Your owners manual may have some of this info?
Oct 28, 2016 | 2000 Ford Explorer
How do you check the transmition oil level on a Nisson navara tekno 2011 automatic
If there's no dip stick you'll have to check it at the transmission pan. Some cars now have a recess in one corner of the pan. You pull the plug out when it's cold and if fluid runs out you're good. If none comes out you have to add fluid through that hole till fluid comes out. If your still not sure take the car to a dealer or a place like valvoline oil change garage.
Jul 01, 2016 | Cars & Trucks
Does a corsa opel ecotec have a transmition fluid were i can pour it my self
is it an automatic? if it is you pour it in the same tube the dip stick for transmission is,, check the level while engine is running and car is in park. if its low then add fluid as needed.
Aug 24, 2014 | Cars & Trucks
Where do you add transmission fluid in 2006 chevy uplander?there is no fluid bbut we can't find where to add more.also we herd weird pulling sound and van started to over heat some.Thank you for your help
Automatic transmition fluid is added through the dip[stick tube. You should use a funnel that is long with a small opening. Auto Parts stores carry funnels just for this purpose. Add small amounts and check the level frequently when adding fluid. the difference between low and full is usually about 1/2 of a quart. If you over fill an automatic its a pain to get the excess fluid out. Check the fluid regularly for a while and add as needed or take it to a mechanic and have them do it.
Aug 18, 2010 | 2006 Chevrolet Uplander
Check transmission fluid
let the engine get hot, park on level ground, open hood, the trans dip stick is at the back of the motor, alot of them today has a yellow or red handle on it. hot in park ,level ground ,pull the dip stick and read on stick, full or add or any fluid touching the stick.hope to help.
Apr 17, 2010 | 2000 Chevrolet Cavalier
Were i chek transmition oil
On the back of the engine towards the firewall, you'll find another dip stick colored red just like the engine oil which is colored yellow. Check the transmission oil with the engine running and the transmission oil at operating temperature. Pull it the dip stick out and wipe it clean and take the second reading, there will be markings on the dip stick to where the transmission fluid should be and never over fill your transmission, thats just as bad as having not enough transmission fluid.
Jan 28, 2010 | 1997 Chevrolet Malibu
How do you check transmition fluid in a 1996 Standard Mercury Tracer?
Check transmition fluid is via the trans dip stick located were the engine meets the tranny.. Dip stick should be labled transmition with the engine hot and car in park. pull dip stick out wipe clean. reinsert into tube fully then remove. the highest oil level is the reading level is reference to the stamped marking on the dip stick indicating fluid level "high or low"
Jan 22, 2010 | 1996 Mercury Tracer
Where do I check and refill the automatic transmission fluid on kia borrego
there is a dip stick at the back of the engine bay but to fill it you must go under the car and pump the fluid into the side of the transmition
Dec 20, 2009 | 2009 Kia Borrego
How can i put transmission fluid into my car,how much do i put in
Check the Level of the transmission fluid by pulling the Transmission dip stick. The colour of the dip stick is most likely red in colour and you need to check it with the car's engine running and hot. Pull the dip stick out clean it off and check it again. always check the second reading.
To fill the transmission, you need to fill it through the Transmission dip stick tube. Yes your going to need a thin funnel and good luck. Do not over fill the transmission. over filling will cause damage to the transmission.
Best thing is, if you have not done a transmission oil and filter change. Have it done at a Transmission shop and you'll know that the transmission level is fine and have them show you have to check and fill the Transmission. As time goes by and mileage get's high, the fluid will get contaminated and the filter plugged up which would in turn cause a transmission failure.
Good luck and hope this helps. Oh and the type of transmission fluid should be in your manuel or stamped on the dip stick.
May 22, 2009 | 2000 Renault 181
Dont know if i should check transmission fluid with truck running
on your engine block your'll have a transmission fluid dip stick that you can use to check it.
please rate this thanks .
Mar 16, 2009 | 2000 Dodge Dakota Quad Cab
Open Questions:
18 people viewed this question
