Question about Samsung Refrigerators
Temperture rising in refrigerator,not cooling. samsung rs2556bb
Samsung rs2556bb all come on is the in side light the front bord has a line on it
Posted on Jun 15, 2012
  • 481 Answers
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 16, 2008
We have a samsung fridge with bottom freezer the freezer is humming and when you open the door it stops and the temperture is rising when you shut the door the humming starts back in a few seconds
defrost issue , not sure on how to jump the board to force defrost but more than likely the defrost thermostat is bad . this is on the evap in freezer . the noise come from frost building up around the evap fan
Feb 25, 2013 | Samsung RB2155 Bottom Freezer Refrigerator
My Samsung RS2556BB refrigerator ice maker is not making ice anymore. The freezer still very cold but there is no water coming into the ice tray. I switched the relay in the back and pressed the water...
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Samsung RS2556 Side by Side Refrigerator
Samsung RS2556BB display is flashing on 34 degrees for refrigerator side; does not seem cool-- what could be problem
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 13, 2011 | Samsung RS2556 Side by Side Refrigerator
Fridge not cooling. Temperature rising
most common problem is the defrost timer motor,it tells the fridge to de ice ,about every 10 hrs or so,if it gets stuck or burns out your evaporator will be a block of ice ,and the fan blowing on it wont transfer cold air,look in the bottom of the fridge by the compressor,
Sep 14, 2009 | Samsung RS2534 Side by Side Refrigerator
Cooling fan dosent come on when temperture rises(1996 pontiac bonneville se) cooling fan relay where is it located..
You seem to have a bad cooling fan switch...it's connected to the side if the engine and when it gets too hot it turns on your cooling fans. The switch doesn't cost that much, $10 to $15 and takes all of about 15 minutes to replace.
Apr 18, 2009 | 1996 Pontiac Bonneville SE CA Value
Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Mar 31, 2009 | Samsung RS2578BB Side by Side Refrigerator
I have a Samsung RS2556BB Refrigerator, purchased in end of year 2004. Looks like the defrost stopped working, cause freezer stop working. A Technicain came as directed by Samsung Customer care, he said it...
Justy a piece of junk. The display has nothing to do with the defrost. Hold your top two buttons for 10 seconds and the displays will reset..good luck.*****
May 30, 2008 | Samsung Refrigerators
Refrigerators Logo
257 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
