Question about Kenmore Oasis HE 27082 Top Load Washer
Whirlpool lsr8233jqo - will not spin
I have the model above, worked fine until tonight. Will not agitate or spin. Not afraid to try to replace a part, just not sure where to begin. Transmission?
  • PL08 Jul 19, 2008
    excellent answer! I replaced the coupling and the washer worked fine again!
    unfortunately, after a few loads of laundry, I have a new problem. Now, the washer fills with water, and then nothing. I try all cycles, nothing happens. I'm concerned I just lost the motor. Is there a way to check that, or are there other things I should check? After doing the first repair I'm not at all afraid to take this thing apart.
    Any help is appreciated. Thank you!
  • lyge Oct 12, 2008
    My Kenmore washer will not agitate or spin
  • 481 Answers
If you hear the motor running then it is most likely the direct drive coupling between the motor and transmission. part #285753 you can see it from under the machine.whirlpool lsr8233jqo - will not spin - 477922b.jpg f3941f5.jpg
Posted on Jul 16, 2008
  • Mike Durland
    Mike Durland Jul 20, 2008
    check the plug on the side of the motor. it will sometimes work loose if it was not plugged in correctly.
     let me know if what you find.
    Mike
Whirlpool heavy duty super capacity plus washer will not agitate or spin. I replaced the agitator dogs but still have the same problem, is this a transmission issue?
Your model may have a flexible (break able) drive component between the motor and the transmission. Check that, it is a pretty easy replacement.
Jan 22, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Washer will not drain or spin
sounds like the timer has failed...try manually selecting spin mode...that should give a indication.
Jul 21, 2010 | Whirlpool Washing Machines
Washer will not spin or agitate. Pump works.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
First, see the following Whirlpool Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If it drains and you can hear the motor trying to turn the transmission for the agitate mode, the obvious first answer is the Motor coupler. I'd replace it just to be sure.
If it's not the Coupler, the problem points to the transmission itself.
There are only two components of the gearcase that are used for both agitating and spinning.
One is the Agitator shaft which drives the agitator and holds the spin pinion that drives the clutch for spinning.
The other is the main "Bottom and pinion gearcase" itself.
Please see the following Whirlpool parts list for commercial top load direct drive washers although the consumer models use the same transmission parts.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 24, 2009 | Kenmore Washing Machines
Drum won't spin, drains ok and agitator works fine
http://www.pcappliancerepair.com/model-display.php This site shows your lid switch. Just enter your model number. The lid switch is the usual suspect for your symptom.
May 09, 2009 | Washing Machines
Whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Ann
Nov 24, 2008 | Estate TAWX700JQ Top Load Washer
Whirlpool LSR8233JQO
The pump is coupled to a motor that runs it. The pump is ok if it is not leaking. You need to check the signal to the motor to turn on. It all comes from the timer switch unit. The coupling probably should be relpaced if the pump is really bad. Sounds like the drive motor for the tub, not the pump, or the switch unit.
Mar 24, 2008 | Whirlpool LSR9434PQ Top Load Washer
Whirlpool heavy duty washer won't spin out the water and is leaking
yes you need to replace transmission and i think the bearinds and seal are all together on that machine
if not replace seal and bowl bearing
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Oasis HE 27082 Top Load Washer Logo
141 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
