Question about Dishwashers
Dishwasher will not cycle. displays code 10
I removed the dishwasher from kitchen recess because I was told It would not heat the water and was not washing thoroughly. I placed the machine on its side to do a continuity test on the heating element. After re-righting the dishwasher to see what happens, the machine indicates it is performing a pre-wash, runs the pump that empties the water out continuously, allows some water into the machine for a short time (approx 1 minute) then cuts the water off (pump continues to run) and displays what I am guessing is a fault code of 10 and beeps every 5 seconds. Discharge pump will not shut off and cycle will not progress any further. I have contacted a local spare parts distributer and the helpful person explained that the code indicated a problem with the pressure switches. Insufficient level is my guess because the discharge pump will not shut off. Help me please.
    Master:
  • 726 Answers
Hello there i have read you review ok there is a fault coming from the water pump there is no way to fix this manully you will need to take it in for a repair witch can cost up to $50 for a new water pump
Posted on Jul 16, 2008
AEG F60873 temperature problems.
The problem when the dishwasher does not heat is failure which requires to remove the qualified personnel and therefore error code is not shown on the display but it is visible in the service mode.
Possible error causes:
faulty heating element
wiring between heating element and PCB
PCB (printed circuit board)
Dado
Aug 24, 2014 | AEG Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Normal wash cycle is over 2 hours?
Hello there
If your dishwasher's cycle times are too long, check these: Water pre-heating Cycle not completing Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater. Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jul 19, 2010 | Kenmore 16919 Built-in Dishwasher
Water heater no go.
The heating element is turned on first during the main wash cycle, which could be approximately 10 minutes in. Since this error is coming up, the first thing to check/replace is the heating element.
I am only familiar with the LDF family of LG dishwashers and on them, to get to the heating element, you pull the dishwasher, invert the entire DW and remove the access panel.
Good Luck, please post back here what you find, OK?
May 07, 2009 | Dishwashers
My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
"HO" flashes on display during washing.
HO, indicates that the dishwasher is using Hot Water. It is completely normal.
Mar 08, 2009 | Frigidaire Professional Series 24 in....
Lg dishwasher never heats water
The LG 7811 dishwasher is supposed to even support a cold water (vs. hot water) connection. Then it will heat the water up to 120 degrees upon each fill cycle. This is not optimal and it adds much time to the already long full cycle. When you run the hot water at the kitchen sink until it is hot and then kick off the cycle, is the water hot at the beginning? It should be 120 degrees minimum and well under 140 degrees maximum.
Do you get any error codes on the display? Troubleshooting is possible, but recommend you contact LG service at the number in the user guide asap. Press for fast, free resolution to this problem. Please reply when you have gotten this fixed, explaining what fixed this nice, quiet dishwasher. Good Luck!
PS: When you get it running, do not use ultra-cheap dishwasher soap. Recommend Electrosol powder or cascade. Never use gel or tablets on this water conserving dishwasher.
Feb 02, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishwasher filling correctly?
john, the dishwasher has a timed fill, make sure you are using 3/8 inch line. If you are using 1/4 inch, that would be your problem. The fill should be just below the heating element. If you are using the 3/8 inch line, the next suspect would be the fill valve itself. Make sure nothing is kinked, Catriver.
Jun 17, 2007 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Long cycle times
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. About the led: If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Dec 30, 2005 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
166 people viewed this question
Top Dishwashers Experts
