Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi 15" Electric bad switch
I need a new switch but cant seem to find one
  • 4 more comments
  • amfritz Jul 25, 2008
    Trimmer died during use and discovered it was the switch. Anybody know of a source?
  • Anonymous Aug 04, 2008
    same here the switch is dead... trimmer dead
  • ranger2131 Aug 05, 2008
    same problem. anyone find a way to get a switch yet?
  • johnlearjet Aug 09, 2008
    took sringtrimer a part.tested and found bad switch.cant seem to find someone that carries the switch. model # of stringtrimer is RY41002.
  • lfink Sep 07, 2008
    Same problem... the RYOBI site seems to offer a replacement Switch Trigger, but not the switch itself.
  • Anonymous Jan 26, 2009
    I have the same problem, the electric switch just stopped working. How do I repair this?
2 Suggested Answers
SOURCE: Ryobi Electric string trimmer
TJ, I've had the same problem since yesterday and I found the solution (lots of googling - that's how I found your post BTW).
It turned out that the switch malfunction is a common problem.
The part number for the FA3-4 switch is:
ut41002a-36 ("switch assembly")
Available here (thru Amazon):
http://factorylawnandgarden.com/product/553902/B000PLVCX8/SWITCH_ASSEMBLY_UT41002A_36/
It's a Homelite part, which is identical to Ryobi.
Here is the manual showing it (part 6):
http://www.m-and-d.com/pdfs/ryobi_tool/RY41002.pdf
Here is the thread with the solution:
http://www.ryobitools.com/dc/dcboard.php?az=show_topic&forum=112&topic_id=597&mesg_id=597&page=3
HTH,
Adi
Posted on Jun 25, 2008
Need a wiring diagram for ryobi ets 1525 table saw switch
http://www.motoruf.de/n/ersatzteillisten.html?id=657306
This is as much as I'm able to find regarding the breakdown and wiring. Sorry I cant seem to fins anything more detailed.
Apr 05, 2013 | Ryobi Table Saw Manual
I'm taking this Ryobi weed eater back to Home Depot, getting my money back and I will not be buying Ryobi again.
Not a bad decision, all in all. Maybe get a gas job. All of the posts concerning electric trimmers on here show ME how problematic they are, how cheap they are and how prone to failing they are! Maybe get a cheap gas job? With proper care and maintenance, these units can last several years.
Aug 13, 2011 | Ryobi 15" Electric Factory Reconditioned...
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
I believe my Ryobi 12 VoltBattery Line trimmer need a new battery
First, check to see if the charger is working properly. To do this, recharge the battery for about 15 minutes. Then check to see if it now runs the trimmer. If so, then you have a bad battery. You can go on the WEB and find a replacement. These batteries or sensitive to heat and cold. When storing, try to place it in a comfortable environment. Sorry for your loss. If it still under warranty, check with the Co.
Dec 27, 2008 | Ryobi 15" Electric Factory Reconditioned...
My ryobi trimmer keep flooding.It has a Walbro carb #wt539 in it.
The most likely possibility is that the carb needs rebuilding. Just cleaning may not help. Gasgets go bad over time if fuel is left in the trimmer.
Nov 11, 2008 | Ryobi 15" Electric Factory Reconditioned...
HTH,
Adi
Jun 10, 2008 | Ryobi 15" Electric Factory Reconditioned...
My Ryobi 15" ElectricTrimmer ZRRY41002 Not Operable
I was thinking about purchasing this product from Amazon sometime soon (today being 4-26-2008).  However after reading of the above problems I am not so sure anymore.  However I did find a discussion about this problem at the Ryobi forums at" http://209.235.218.9/dc/dcboard.php?az=show_topic&forum=112&topic_id=597 ".  (If the link does not work go to " http://209.235.218.9/dc/dcboard.php " and do a search for " 597 ".  One of the displayed threads will be entitled "weedeater problem?"  It will have the proper link to the discussion.)  From multiple postings in that thread it appears that the switch is the problem and it seems to be a consistent problem for many users.  The switch itself can be replaced for less than $4, however the shipping seems to drive the cost up to anywhere from $12 to $15, unless one can find a local supplier.  I hope that this helps.
v_v
Apr 15, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
108 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
