Question about O2 Xda II mini
O2 mini does not boot up
Hi when I start my O2 mini, only the backlight turns on but no boot up.. please help me. i dont wanna hard reset my PDA.
  • Anonymous Aug 22, 2008
    I also having the same problem it only show the charging light as red but not being ON.
How can i get my pocket pc CD instillation
Posted on Jul 21, 2008
To start internet using my O2 xda mini s
i dont think its possible with windows mobile phones as they use activesync to communicate with the computer but you can try Windows Mobile Center but im not sure
Mar 07, 2010 | O2 XDA Mini S Smartphone
How to install software O2 Xda II mini
There are two methods:
  1. Connect you O2 Xda to your PC using your USB cable. Connect using Active Sync. Double click the .exe setup of the software you want to install on your PDA. Follow the onscreen instructions.
  2. Directly open the .cab file (if you have) for the software you want to install on your PDA. The installation should start automatically.
Please rate if helpful...
Sep 07, 2009 | Computers & Internet
Slow respond
The best solution to these problems is hard resetting your device. A hard reset will bring your PDA to it's factory default state, so your PDA will be as fast as it was when it was brand new. But this process will erase all your stored data (Such as adress book, messaged, appointments, tasks, pictures, ...) so you should consider having a backup of your PDA to your PC with a backup software before you hard reset your device. So later when you hard reset, you can recover the personal data with this backup file and continue using your PDA faster.
To hard reset your PDA, you must press the on/off button and reset button at the same time (reset button is a small button that needs to be pressed with your pen, and usually it is located in the bottom of the PDA). And later, wait a couple of minutes and the windows will be reinstalled and load up with the starting page of the screen alignment. After you completed all the settings, you can recover your data from your backup file (from PC).
Apr 03, 2009 | O2 Xda IIs Pocket PC
How to hard reset my O2 xda II mini
This is a link for your manual which will show you how to hard reset and all else you need to know. Hope this helps!
Mar 16, 2008 | O2 Xda II mini
Do not work the clear storage tool to hard reset.
format your pda and reinstall the os and this will solve your problem
all the best
Feb 01, 2008 | O2 Xda Orbit Smartphone
O2 xda exec
This is the suggestion they provide on O2 website for such problems:
  • Perform a soft reset (PDA phone) or re-boot the device (Smartphone) and test again.
  • Perform a hard reset (PDA phone) or return to default settings (Smartphone) and test again. (read below before dong this)
  • Check that the application still fails to execute after you upgraded the ROM (OS) to the latest revision. If you haven't upgraded your ROM (OS) do so now and check again.
But before doing the hard reset, I suggest you try installing other camera software for windows mobile 5 and check if the camera still working (not a hardware problem). If its still fail, try the hard reset after backing up all you data.
Jan 31, 2008 | O2 Xda Atom Exec Smartphone
My o2 does not boot.
have you tried to reset all the settings? some of the application has corrupt. if it persist reformat you xda
Jan 26, 2008 | O2 Xda II mini
Where can i dowload driver ?
download the Microsoft ActiveSynk from https://www.microsoft.com/windowsmobile/downloads/eula_activesync45_1033.mspx?ProductID=76 and hopefully you willbe able to connect your PDA to the computer
All the best
Nov 29, 2007 | O2 Xda II mini
O2 xda orbit shuts down after several minutes
hi there..
it seems the os of your phone shomehow got curropted..first hard reset your phone using.... camara+recording button+power button and reset it with stylus....but you will loose your data stored on phone.....bet data on storage card will be saved........if this solve your problem...thats great...in case if not...reinstall the os on PDA...this will surely solve your problem...
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Aug 23, 2007 | O2 Xda Orbit Smartphone
O2 PDA is not working after Upgrading the software
I would say that either the upgrade package is not compatable with your device and has not installed anything beyond flashing/deleting the current installed eeprom info (no info on the eeprom at all) or the device has been restarted or uplugged during the flash eeprom stage, the factory/master reset should take you back to config mode at least, when trying the master reset the power should be on, then activate the master reset with a paperclip or pin only will work, press and hold until the red light goes out, remove the pin or paperclip activator and your device should power up as normal with the old eeprom info or ready for new eeprom info to flashed onto it if you are successful here ensure you use the istall package that came with this device Should be WinMobile/II or IIe I think.
May 17, 2007 | O2 Xda II mini
Computers & Internet Logo
96 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
