Question about AudioBahn Car Audio & Video
I want to install a audiobahn aw 1251x subwoofer and Hifonics mercury 10 2x50w 2/1 channel 1 ohm stable amp to a stock stereo in a 2003 dodge intrepid, how do i wire it?
  • 109 Answers
Get an aftermarket to factory wiring adapter. You can find out exactly what part you need by following this link:
http://www.crutchfield.com/cgi-bin/autoinfo/autoinfo.asp?lp=%2fapp%2fCar%2fMyCar.aspx
Posted on Jul 17, 2008
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
Wats the best way to hook up 3 hifonic hfx12d 12s. Dvc 4ohmd to a 2 channel 2600 watt planet audio. Amp is 2 ohm stable.
Wire each sub 8 ohms(sieries) than connect them in parallel, bridged @ amp, final impedence will be 2.6 ohms.
Jan 30, 2014 | Hifonics Car Audio & Video
What would be the best size amp to purchase for two audiobahn aw1200 subwoofers and two pioneer 4-way 6"x9"?
First, I would purchase the amp based on the subwoofers alone. Allow unit power to run the 6x9's unless you are planning a intricate setup. Things to think about when buying your amplifier. Always get an amp that offers an RMS output of 25-30% greater than the combined RMS output of your subs. Also, the stability of the amp to handle ohms loads (1, 2, or 4 ohm stable). If you have two dual 4 ohm subs you can get a 2 channel 2 ohms stable amp, or a monoblock 1 ohm stable amp. This will get you the most power and sound for your buck. There are so many amplifiers out there at different price levels, it's really up to you. Hope this helps.
Sep 03, 2011 | AudioBahn AW1200 Car Subwoofer
I have 1 audio bahn eternal series awes15p 15inch subwoofer.I'm having problems hooking it in my vehicle,I don't have the wiring manual.I would appreciate if you can tell me or give me a...
There are some things to think about when you install this.
1. Is the sub a dual or single voice coil?
2. What ohms are the voice coils?
3. Is your amp 2 channel or mono?
4. What are the ohms loads allowed by your amp?
I am going to assume your sub is dual 4 ohm and you want to get as much power out of your amp as you can. I am also assuming the amp is a mono channel amp. (if it's a two channel amp, you can bridge the channels)
Go from the positive of your amp and wire to both positives of the voice coils. Then go from the negative of the amp to the negative of both voice coils. You will have 2 sets of wires to your sub. This is called a parallel set up. This drops the load of one dual 4ohm sub to a 2 ohm load. The lower the resisitance, the more power is able to flow from your amp, giving your more sound. Make sure your amp is 2 ohm stable.
Hope this helps
Aug 25, 2011 | AudioBahn AW1500 Car Subwoofer
I have two audiobahn aw1500 15" subowoofers and i was trying to figure out how to wire them so that they come to 2 ohms. I have a Kicker 400.1 amp that is 2 ohm stable.
What is their ohms at the moment. If they are 8 ohms the will become 4o hms in parallel, 4 ohms will become 2 ohms in parallel. Since your audiobahns are dual four ohms coils one speaker wired in parallel gives you 2 ohms and both wired together in parallel will give you 1 ohms. You will need to wire them in series parallel to to keep two ohms and that is a waste of power. Kickers are good amps, with a little extra cooling the amp should sustain the 1 ohm capability of your parallel connection or trade in for a 1ohm stable amp
Apr 02, 2011 | AudioBahn AW1500 Car Subwoofer
Hello..im trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
Mar 22, 2011 | AudioBahn Car Audio & Video
How should i arrange the wiring on my xm-zr1852 xplod amplifier to get the best performance out of my 12'' audiobahn subwoofers?
it depends on the impedance of the subs-if your subs are dual 4 ohm coils then you can parallel the coils which will give you 2 ohms per sub- you could get max performance from your amp by just wiring the 2 ohm speaker load to each channel of the amp which will hit them with about 200 watts rms each. another way to do it is to wire the coils in series which will make each sub an 8 ohm load and then parallel them together and that will show a 4 ohm load -which you can use to run the amp safely in bridged mode. This will give you exactly the same amount of power to your subs as in 2 ohm stereo will. so with your amp being 2 ohm stable in stereo or 4 ohm stable in bridged mode- those are the numbers you want to hit for maximum"safe" operation
Dec 10, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Wiring a 10 inch dual voicecoil dub100 so its bridged the right way
yes sir. You can find out every single option for the amount of subs and the impedence. This will show you your wiring options. Plus remember when you bridge your amp you are Halving the ohm that is going to the 2 channels. SO if it is stable at 2 ohm at each channel. And you already have a 2 ohm load from your subs your amp will go into protection over and over again and eventually fry up cuz you will be putting 1 ohm load at each channel.
May 06, 2009 | AudioBahn DUB100 Car Subwoofer
How bridge the 15" 800 rms speakers audiobahn
parallel wiring (if your amplifier is 1 ohm mono stable)
All positives together and all negatives together.
If your amplifier is not 1 ohm mono stable you will need a series/parallel which is a little more difficult.
Here is a wiring link.....
http://www.the12volt.com/caraudio/woofer_configurations.asp
Dec 16, 2008 | AudioBahn AWES15P 15" Subwoofer Car...
Aw 1251 audiobahn 400w. woofer
Yes, wire the Voice coils in series. This will give you at least 4 ohms.
Amp+ to VC1+
VC1- to VC2+
VC2- to Amp-
Nov 16, 2007 | AudioBahn AW1251 Car Subwoofer
Car Audio & Video Logo
241 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
