Question about Amana AFD2535DES French Door Refrigerator
Amana refrig My refrigerator temp is too warm and my freezer is too cold. The fridge is on the coldest setting.
  • cessg Jul 16, 2008
    There is no frost in the freezer. The coils are clean. The cool air is
    not getting to the fridge from the freezer. The vent isn't blocked...
    Cessg
  • 481 Answers
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 16, 2008
  • Mike Durland
    Mike Durland Jul 16, 2008
    • none of my free suggestions have helped you at all?
    •  if you feel the issue with the machine is something else let me know, i will try to help you figure it out.
    Mike
Warm temp. on door of refrig.
The fan on your freezer may have given up thus the cold air inside the fridge doesn't circulate.
Apr 12, 2014 | Whirlpool Refrigerators
My fridge is warm but freezer cold
a little door from freezer to fridge gets frosted shut. you need to defrost the freezer then run it on a medium temp not the coldest setting. also make sure to not over fill the wall in between the freezer and the refrigerator. (thats where the air crosses over) unlessp u have an over and under freezer refrige set up in which case your little door is in the floor of the top compartment and the roof of the bottom one. good luck
May 07, 2011 | Refrigerators
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Mar 09, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
Our refidgerater is not cold enough running at about 50 degrees
hows the freezer?? is only the refrig warm and freezer still frezzing?? if so id open the freezer door and listen for a fan motor, it should be spinning to circulate air to the top sect(refrig). if not on sounds like a bad fan.. if the fan is on but the rear panle is completly iced over, sounds like a defrost issue
Nov 16, 2008 | Amana ABB2223DES Stainless Steel Bottom...
Amana AFD2535DES French Door Refrigerator Logo
151 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
