It sounds like there may be a compatibility issue between your Bose Lifestyle V30 home theater system and the Sony Blu-ray player when switching to the DVD input. The change from PCM 2.0 to AAC audio format might be causing the loss of sound. Here are some steps you can take to troubleshoot and resolve the issue: Check Blu-ray Player Audio Settings: Access the audio settings on your Sony Blu-ray player and ensure it is set to output PCM audio (if available). Some Blu-ray players have options to change the audio output format. Setting it to PCM 2.0 might help maintain audio compatibility with your Bose system. Check Bose System Settings: Review the audio settings on your Bose Lifestyle V30 system related to the DVD input. Make sure it is configured to accept PCM audio. Refer to the Bose user manual for instructions on how to access and adjust the audio settings. Firmware Updates: Check if there are any firmware updates available for both the Sony Blu-ray player and the Bose Lifestyle V30 system. Manufacturers often release updates to address compatibility issues and improve overall performance. Reset Bose System: Try performing a factory reset on your Bose Lifestyle V30. This can sometimes clear any configuration issues that may have arisen. Test Different Audio Inputs: Check if the issue persists when connecting the Blu-ray player to a different audio input on your Bose system (e.g., AUX, HDMI, etc.). This will help determine if the problem is specific to the DVD input or if it affects multiple inputs. Alternate Audio Connection: If possible, try using a different audio connection between the Blu-ray player and the Bose system. For example, if you are using HDMI, try using optical or analog audio cables (and vice versa). Contact Bose Support: If the issue persist
It looks like there may be compatibility issues between your Bose Lifestyle V30 home theater system and Sony Blu-ray player when switching to the DVD input. Switching from PCM 2.0 to AAC audio format may cause sound loss. Here are some steps you can take to troubleshoot and fix the problem. Check Blu-ray Player Audio Settings: Go to the audio settings on your Sony Blu-ray player and make sure it is set to PCM audio (if available). Some Blu-ray players have options for changing the audio output. Setting PCM to 2.0 can help you maintain audio compatibility with your Bose system. Check Bose System Settings: Check your Bose Lifestyle V30 system's audio settings for the DVD input. Make sure this PCM is configured to receive audio. See the Bose User Guide for instructions on accessing and adjusting audio settings. Firmware updates: Check if there are any firmware updates for the Sony Blu-ray player and the Bose Lifestyle V30 system. Manufacturers frequently release updates to address compatibility issues and improve overall performance. Reset Bose System: Try performing a factory reset on your Bose Lifestyle V30. Sometimes this can cause scheduling issues. Test audio inputs: Check if the problem persists when connecting the Blu-ray player to a different audio input (e.g., AUX, HDMI, etc.) on your Bose system This may indicate whether the problem is specific to the DVD input or affects multiple inputs It will help determine whether. Extra audio connection: If possible, try to use an extra audio connection between the Blu-ray player and the Bose system. For example, if you use HDMI, try using optical or analog audio cables (and vice versa). Contact Bose Support : If the issue persists
the tv's hdmi connection is an INPUT, not an output. to get tv sound through hdmi, you have to connect the hdmi OUTPUT from a dvd/blue ray or a cable/satellite box. your tv may have digital audio out on a seperate jack, possibly a fiber optics connection, which you may be able to run into your stereo. however, most tv's do not have audio outputs, you have to get the audio signal from a disk player or cable box 99% orf the time.
First off get the arcsoft media converter 3, then drag and drop the videos you want to get on your mp3 player into the program, after it converts it loads them onto your mp3 player as long as it?s connected, this program will also allow you to download YouTube videos and put them on your mp3 player too.
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector
2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
hi yes it is....
wot u need to do is.....our red and white audio leads go from sky box to dvd box...we then put our dvd player onto video 1 using function button on remote
hope this helps
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video: All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
Video out from cable, HT, and combo player.
Video in to TV. Your choice of inputs.
For audio: Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
Audio out from cable box and combo player.
Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
