Question about Lenovo 3000 Y410 Laptop
USB drive not recognizing
Hi Friends,
I have been using Lenova y410 laptop for the last sixmonths, but for the last one month my usb drive not working properly. Basically it is not recognising. But even Mouse remaining things it is recognising properly.
Even drivers also updated . Kindly resolve this problem.
    Genius:
  • Lenovo Master
  • 1,250 Answers
Check your usb drive on some others system , if the problem is the same , then its the fault of your device replace it
Posted on Nov 04, 2008
I am trying to download movies off my friends portable hard drive onto my laptop but when I plug in my friends hard drive into my laptop, my laptop don't recognize it and nothing comes up???
Your laptop's usb port may not have enough power to keep the portable hard drive running.
You may require additional power to the portable hdd by using a usb cable with 2 usb connectors.
or use a USB port that is powered.
Mar 03, 2011 | Computers & Internet
I wnt 2 install widows 7 in my lenovo y 410 54Q note book... i want drivers for installing windows 7 62 bit or 32 bit drivers needed
Firstly go to Lenova's web site and make sure that Win7 supports Lenova 3000. If it does, check 64 is supported.
If all is OK, download the 64bit drivers to a USB flash drive or burn them to a cd.
Back up all of your data!!
Put Win7 64 system disk in your DVD drive and boot from that.
Follow the prompts and be certain to install A CLEAN INSTALL.
If you don't you will bring problems with you from your old system.
When Windows has finished installing, go through all of your programmes, installing them, as you have an empty drive to put them on, then install the 64bit drivers from your CD or USB drive.
Good luck and I hope this helps.
Nov 23, 2010 | Lenovo 3000 Y410 Laptop
I have a Hitachi Simple Drive Mini x 320 GB that I've been using as an external for my macbook pro. I have been using it without problems for over a month now, but last week it didn't eject properly from...
does the usb cable you are using have 2 usb plugs so you can plug it into 2 usb ports at the same time.
If not, you could try using one, sometimes my external HD will not work on some pc's if i just plug it into 1 port
Sep 10, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
My computer ideapad lenova,i am not able to connect to internet,one IT specialist told me that my slot for inserting cable is bad what to do i am now in china Ghanzhou city
Do you mean the slot?
Is it the cable that goes into the LAN port?
If so you can use a LAN PCMCIA card and connect the LAN cable into this card.
OR
You can connect to the Internet using a USB 3G adapter which uses the cell phone network with a cell phone provider.
Aug 05, 2010 | Lenovo 3000 Y410 Laptop
DVD drive does not recognize dvd's
may be the problem with dvd drive. its not reading dvd means it lence has some problem.
Jun 17, 2010 | Lenovo 3000 Y410 Laptop
Laptop does not allow auto run of USB drives / Pen drives
What do you mean "doesn't allow"? does it show you any kind of error?
I would like to suggest you to plug your USB drive into the laptop, and then go to "start"-> "control panel"-> "add hardware" and see what you have.
you may have to install manually the USB on your laptop, so it may recognize it.
Nov 11, 2009 | Lenovo 3000 Y410 Laptop
Web cam Problem
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 05, 2009 | Intel Easy PC Camera Webcam
Mousepad not working
Hi Sharad arya,
Try pressing Fn+F8 to activate/deactivate touch Pad.
takecare.
May 12, 2008 | Lenovo 3000 Y410 Laptop
USB DEvice not recognized
My apologies faizakhatib. I see that you did, indeed, provide the make and model of you laptop. Thank you for that.
Some additional suggestions:
(A) Please, make sure that your laptop's A/C adapter is plugged in while trouble-shooting this issue. We don't want to complicate the matter w/ a possible low-power issue.
(B) Worse case, your laptop's USB interface may have failed (hardware failure). To repair this would necessitate replacing your motherboard. You can work around this issue, however, by using a laptop PC card w/ USB ports.
Please, get back to us w/ your answers and we'll work w/ you to diagnose this issue.
Thank you,
BJ
Apr 02, 2008 | Dell Inspiron B130 Notebook
External drive is not recognized on my laptop and PC
Hi
This is not a problem.
U can select the program by default
Oct 22, 2007 | Toshiba 512MB USB 2.0 High-Speed Flash...
Lenovo 3000 Y410 Laptop Logo
126 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
