Question about Estate TAWX700JQ Top Load Washer
Machine problems why does my wasing machine jump around on the spin cycle
  • 481 Answers
  • first, check to see if the yellow shipping strap has been completely removed.
  • next make sure the back legs (self leveling) are not stuck. tilt the machine towards you lifting only the back of the machine and drop it down, this should reset the back legs (if they are not stuck). if they are stuck then hit them down with a hammer.
  • another thing would be the springs that stabilize the tub. look under the machine and you can see if they are still attached.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Posted on Jul 16, 2008
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
Wasing machine washes fine, once it gets to the spin cycle it stops and just makes a slight hmmmmmm sound. and wont drain or spin.
What brand of washer do you have? If you put that info in, it did not come through with your question and we need that info to give you the correct information to help you fix your problem.
Jun 23, 2015 | Washing Machines
Machine wases & epties just wont spin motor ok brushes around 20mm long filters all cleaned not sure where to go next?
Hello there,
Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes. Hope this helps. Mike
Jul 27, 2011 | Washing Machines
Wasing machine stops spinning during final spin - 3 or 4 minutes into the cycle.Frigideaire front end loading washing machine.
You could be using too much soap that will cause the machine to go in oversuds motor protect and shut down . Do make sure you are using HE soap and only about 2 to 3 table spoons per load .The next most likely cause would be the door lock but I think you have a soap problem..Good luck need more help please ask Thanks for Voting
Mar 13, 2011 | Frigidaire ATF6000ES Front Load Washer
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Mar 02, 2011 | Kenmore Washing Machines
Wasing machine stopped begore end of spin cycle half full of water
I dont know what type of machine you have.
It sounds like the pump is the cause of the problem,it has stopped pumping the water.its probably blocked with debris.
May 29, 2010 | Washing Machines
Washing machine is jumping around on the spin cycle
A few possibilities here.
Make sure the washer is level, both back to front, and side to side.
Do not over load, and make sure that there is more than 1 article in it, otherwise you will get an out of balance load.
Make sure the water is drainlng away properly.
Check the drum for excess movement, this would indicate a broken spring or worn drum bearings or worn or broken drum shaft.
Check the concrete wieghts at the top and bottom are not loose or broken.
Check the suspensions for excessive wear.
Hope this helps
Mar 31, 2010 | Maytag Performa PAV2200
Amanna wasing machine 3.2 cu. ft. top loader
i would try removing the lower acess panel(2 5/16 screws . from there you should be able to see where the "ticjing" noise is coming from, likely source is cracks in belt assy
Oct 07, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Estate TAWX700JQ Top Load Washer Logo
50 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
