Back to:
Tags:
Epson Stylus CX6600 All-In-One InkJet Printer
Where do the cords plug into
posted by sh-lynn on Jul 16, 2008
where is part b located on the printer
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 09, 2008
Helpful (85)
magus
Rank:Apprentice Apprentice
Rating: 90%, 3 votes
lift the document table [as if you were going to replace an ink carrtidge]. On the extreme left hand side of the unit [viewed from the front] a narrow channel can be seen. This is where the usb cable sits. At the end of the channel, which curves towards the centre of the machine, is the usb socket [not visible from directly above i]t. Plug the squarer end of the usb cable firmly into place and press the cable into the channel so the document table can be returned tio the closed position. jfm.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on where do the cords plug into:
I don't want to Accept this solution
Can you Help with these Printers problems?
Epson Stylus CX6600 All-In-One InkJet...
the scanned picture shows with vertical areas of varying...
I just replaced all the ink cartridges and did a few head...
When printing on glossy paper. on start printer makes...
When printing the black does not work, all the other...
have used epson print cartridges for replacement, but the...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
