Question about Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Mounting Tubeless tire on Rim of riding lawn mower
I have a flat tire on one of the Larger rear tubeless tires on my Yard Machines MTD riding mower. The problem is when I apply air from hi-pressure hose, there is no way for the tire to seal around the rim so it inflates. There must be a trick to get the tire to basically puff up so it expands over the rim. One auto tire guy suggested rubbing soap and water around the tire seal on both sides and as I apply air push in on the tread......well no that didn't work.
The mower is on a jack lift so the tire spins freely.
I'm using a mechanic shop quality air pressure electric pump.
That's the deal. Thanks George.
With the mower jacked up place a belt or rope around the center of the tire all away around and draw it tight. Apply pressure and when the tire starts to fill you can release the belt. Apply pressure until you hear the bead pop, indicating that it has a bead lock to the rim. Let the air out to the right pressure, check all tire pressures and set the deck to level. Go mow your lawn.
Posted on Aug 23, 2009
WOW YOU WILL LOVE THIS TAKE OFF LAWN MOWERMounting Tubeless tire on Rim of riding lawn mower - 2_bing.gif TIRE SET IT UP ON TWO BLOCK,S AIR VALVE UP, OK NOW GET COLD VASALENE PUT IT AROUND BOTTOM FIRST PUT IT ALL THE WAY AROUND ON RIM TO FILL THE GAP NOW HAVE SOMEONE PULL UP ON TIRE PUSH DOWN ON RIM AND HOLD WHILE YOU PACK THE TOP PART UP ALL THE WAY AROUND TIRE FILL ALL HOLES THEN PUT AIR IN THRUE AIR VALVE THE VASALENE WILL PUSH OUT AROUND SIDES SCRAPE IT OFF TO USE NEXT TIME!!! P.S. COLD GREESE WILL WORK TOO BUT VASELENE IS THICKER!!! SO NOW PASS THIS ON TO YOUR FRIENDS THEY WILL PAY YOU FOR SAVING THEM HOURS OF STRUGELING WITH LAWNMOWER TIRES2_bing.gif
Posted on Feb 18, 2010
I Went to Yahoo Answers and received many suggestions free of charge.
You guys seem to be more focused on making revenue and have provided no anwsers.
So, I pose the question?
WHO YOU GONNA CHOOSE?
Posted on Jul 16, 2008
Saw this somewhere - use rubber cement. The picture is what I did - used a generous amount of cement to get a seal around the rim and tire bead. It worked well. When I filled the tire, the excess rubber cement squirted out the side and I just wiped it off, but it worked and kept air. You have to wait for the cement to nearly cure on one side before flipping it over, otherwise the cement runs. I used a cement block to hold the tire with the shaft still on it -- shaft goes down the block hole.
Posted on Apr 11, 2010
  • 120 Answers
The trick is you are going to need a bead sealer device that sprays a mass of air at one time to seal the tire .they cost 200.00 so i suggest goint to a tire shop and give um da 10 bucks sorry
Posted on Aug 16, 2008
My car is a 1995 Pontiac Bonneville. The last time I purchased new tires the size was 215/65R-15 96H Allseasons blackwall ....balanced w/ tubeless valve stem
the size is still available from most quality tire retailers
the all seasons black wall may be out of production and all tubeless tires get a new valve stem in the rim
Aug 08, 2017 | Pontiac Cars & Trucks
Tip
Seal bead on flat tire to refill with air
Most lawn tractor tires are now tubeless and when they go flat the seal of the tire bead and rim are lost. It is very difficult to restore the seal in order to refill the tire and determine what caused the flat. Here is my tip to seal the bead, & fill the tire, without having to remove the wheel from the tractor. Wrap a length of heavy rope, or a fabric hold down strap centered around the outer circumference of the tire tread and secure with minimum slack. Place a bar, long box wrench etc. between the rope and tire and turn in whatever direction you choose keeping the ends of bar above the rope. As you turn the rope will begin to twist and cinch and collapse the center of the tire causing the bead to evenly seal against the rim.
Add air until you feel pressure building then back off cinch as you fill until you are sure bead will hold on its own. This works great on wheel barrow tires as well.
Good Luck
on Apr 02, 2015 | Garden
Where can I find a Duro 130/90-10 61 J Tubless
Duro Front or Rear HF290 130/90J-10 Blackwall Tire - 25 ...
https://www.denniskirk.com/duro/front-or-rear-hf290.../543621.sku
Duro Front or Rear HF290 130/90J-10 Blackwall Tire - 25-29010 ... and stability;Tubeless; Blackwall; Sidewall ID Information: Duro HF290 130/90-10 61J.
Bicycle tubeless tire 130 / 90-10 61 J HF-290
global.rakuten.com > ... > Tires > Scooter Tires > Below 10 Inch
Product name, 130/90-10 Duro DURO-inch tires. Manufacturers, DURO (Duro)-. Fits size, 130/90-10. Accessories, Without. And DURO, DURO tire E marked ...
Oct 29, 2015 | Computers & Internet
Which tyre best for honda cb shine 80/100-18 tubeless or 3.00-18 tubetype
Hi Nagraj, it all depends on what type of wheel you are running. If your wheel has spokes you must use a tube, if your wheel is cast you can run tubeless. Good luck
Apr 06, 2015 | Honda Motorcycles
Back tyre removal
Most a e-clip holding tire on. I use a tubeless tire repair kit. Blow the tire up, find the leak and use kit repair.
Jan 01, 2014 | Husqvarna 23HP VTwin Hydrostatic 48" Cut...
Tubeless?
Look at the hole where the air would go into the tire., and at the rim itself. Although I never heard of a tubeless bicycles tire, except for the solid rubber tired ones, there may be some of the racing bikes or VERY expensive models that do not have tubes. If your rim has a plain hole, it should be using a tube inside the tire, same as a wheel barrow. If there is a valve stem with a core mounted in the hole, not connected to a tube, it is tubeless. Most bicycles rims also are not air tight, because of the holes in the rim for the spokes. This means there are about 30 - 40 holes beside the hole for the valve stem of the tube. Those holes have the nut of the spoke in them, and are usually covered with a wide "rubber band" to keep the tube from being punctured by the spokes.
Be blessed.
Jul 30, 2013 | Mongoose Xr200
Sears lawn tractor tubeless tire replacement
Most local tire shops have or can get tires and tubes of the size you want/need and would install them as well. Without the proper tools, they can be a "bear" to change but if you insist upon doing it yourself, go to a GOOD lawnmower repair shop and have them order the sizes for you. It has been my experience though, the tire shops are cheaper
Sep 14, 2009 | Garden
Tube or tubeless??
If the rims are with spokes they use tube.If it has aluminum rims (like a street bike) then you can install tubeless tires
Jun 09, 2009 | 1991 Suzuki DR 650 RS-E
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966 Logo
2,885 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
