Question about HP Officejet Pro L7680 All-In-One Printer
Fax wont work
This is a new replacement machine from HP ...I have never faxed frm this machine. When I put multiple papers in the feed one passes all the way thru and the second gets jammed. Is there some sort of shipping stuff that I forgot to remove because I cant find it.
    Novelist:
  • 106 Answers
HI,
here is the document that i want you to follow. On this document, just go gown further and STEP FOUR: OPEN THE TOP COVER AND CLEAR THE JAM.
CLiCK HERE TO GET THE DOCUMENT ==> DOCUMENT
Please let me know the outcome after following the document.
Thank you so much.
adonscott
Posted on Jul 19, 2008
Multiple pages
Actually, when you get more than one paper feeding in at a time, it is almost always the separation pad being worn down. Go here to buy a new sep. pad and tell them Ken from National Cartridge Co. sent you there!
http://www.precisionroller.com/paper-feed-components-for-brother-intellifax-5750e/details_9248.html
May 28, 2010 | Brother IntelliFAX 5750e Laser Fax
Front loading page grab problems.
See that top on which to place paper faxing is a green button should be positioned (to the right or left) in position with several sheets drawn as an indicator. I guess yours is positioned on a single paper which means it does not separate anything you ask.
Good luck to configuration
Oct 30, 2009 | HP LaserJet 3200se Printer
Feed tray pulling multiple pages
prior to the issue ,it can be the sign of wear and tear of the feeder seperation pad .may i know is the fax heavily utilise.if yes get the part to change ,if no try to change your paper or frequently fan the paper it can be highly moisture present on paperand try to minimise using reuse paper it may shorten your machine lifespan.good luck thanks pls rate me!!!!
Aug 27, 2009 | Canon LaserClass 2050 Plain Paper Fax
Broken paper guide and difficult fax input.
Lets start with the paper feed problem. You need a new paper feed roller to pull the paper in when it should. You need a new seperation pad to prevent multiple pages from being fed at the same time. you will have to look at your machine to determine which parts are needed. here is a link to a company that I do business with. You can find the trays here also.
http://www.precisionroller.com/manufacturers/brother-intellifax-4750e.html
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax machine pulls fax material into fax unevenly,so cannot fax...
If you take some alcohol, and put a couple of drops in the center if a piece of paper, then pass it through the feeder a couple of times, this should clean the feed and seperate tires, do this a couple of times, then try passing a couple of sheets to see if the problem has been eliminated.
Hope this helps.
Ed
May 06, 2009 | Canon FAXPHONE L80 Laser
Pages sticking together when transmitting
This is caused by the feed and separator rollers are dirty or worn out. The simplest thing to try is to clean the feed rollers. you will need a cleaning solution, isopropal alcohol works very well. Available at local drugstores. you can approach this one of two ways, you can open up the document feed section and manually clean the rollers or put a few drops of Alcohol in the center of a piece of paper let it soak in a little and pass it through the document feeder, the paper should have a streak on the last half of the page if it made contact with the rollers. For best results do this a couple of times, for better results do both the manual and the pass paper methods.
Hope this is of some assistance.
Ed
Apr 20, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Sharp UX-A1000 Fax Machine Document Feeding Trouble
Problem is most likely caused by a worn paper pick roller. It would be more expensive to repair this fax than to just replace it.
Nov 28, 2008 | Sharp UX 108 Roll paper Thermal Fax
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
HP Officejet Pro L7680 All-In-One Printer Logo
Seeker5211
Seeker5211
