Question about Samsung (TS-H552B) DVD±RW Dual Layer Burner
Samsung DVD±RW Dual Layer
I have Samsung ts-h552b dvd±rw dual layer burner that will not open or close like it should and now when I try to burn a dvd it starts running & will not shut off. I have to restart my computer to get the disk out. This is the 2nd drive I've had to do this. Emachines replaced my first drive because the pc was only 6 months old, but now it's out of warranty and it's doing the same thing! Any suggestions on how I can repair it myself? Can the little 'belts' inside be replaced, if so how do I go about it? Thanks
  • nancynichols Jul 16, 2008
    Thanks. I guess I'll have to buy a new one, but it will not be a Samsung. I'm not giving them a chance for a third strike! Also, I can't find the pinhole to open the drive, I knew about that, but this unit must not have one.
  • Samsung Master
  • 2,794 Answers
With the price of those units, it's usually cheaper to replace them. You could check with Samsung and find out if it's still covered under their warranty.
Posted on Jul 16, 2008
  • Tim Babcock
    Tim Babcock Jul 16, 2008
    Theres a hole in the front of your DVD player. If you have a paper clip, you can instert it in there and it will manually open the drawer if necessary.
4 Suggested Answers
  • 46 Answers
SOURCE: Sony DW-G120A DVD RW Dual Layer Burner
U can use nero, first of all you must format de DVD-RW, so that it can be be rewritable. Then use it like a normar DVD-R disk. And every time you want to rewrite the DVD only make a quickformat and put your things on the DVD.
Posted on Nov 09, 2007
  • 55 Answers
SOURCE: internal dvd writer not reading/writing dual layer dvd rw
try different type of media
Posted on Mar 30, 2009
  • 5660 Answers
SOURCE: I have lost my power cord to my LaCie DVD+RW Dual Layer....
Here is the PDF Users Manual for the LaCie DVD+RW 301230U
external optical drive,
(Give it at least 10 seconds to download)
Should the direct link above not work for you, you can download the Users Manual from here,
Go down to the bottom of the page, and under the green -> Download Now <- heading, click on -> User Manual
The reason I posted the link to the User Manual, is that you can use a USB to USB cable for power. You plug one end of the USB cable, into an available USB port on your computer, and the other end, into the LaCie DVD+RW external optical drive. (You need two available USB ports on your computer. One for power, and one to connect the LaCie external optical drive. This USB cable, is called an Interface cable)
The USB end, that goes into your computer, (Laptop or Desktop computer), is the USB A style end. (Male) This is what it looks like,
The USB end, that plugs into the Lacie optical burner drive, is a USB Mini-B style end. (Male) It looks like this,
It is the second one from the left side.
Where I'm at, we have Walmart stores. At Walmart they sell a USB adapter kit, made by Philips. This kit has a USB A to USB A cable, that both ends are Male. This cable is on a little retractable reel. The reel is about the size of a USA fifty cent piece. In the kit are five different styles of USB adapter ends. They just plug on that USB A to USB A style cable. (On the small reel) One of those adapter ends is a Mini-B USB male end. It has a Female USB A socket on one side, and a Male USB MIni-B end, on the other side. The kit sells for about $12 dollars.
Should you find that somehow, this USB power cable does not give enough power to your LaCie external optical burner drive, then here is, Products, Support & Downloads, and the Power Supply, for your LaCie DVD+RW 301230U external optical drive,
Posted on May 16, 2009
I have a Mad Dog DVD±RW Dual Layer Burner
Try checking your settings in the burn menu.Many programs give you the options to burn at slower rates.Good Luck
Jan 06, 2011 | Mad Dog Multimedia DVD±RW Dual Layer...
If there is a pin hole in my drive, I can't find it. I have Samsung ts-h552b...
If the power goes or the drive refuse power up then follow this simple step to open it
1.) locate a small hole in the front of the drive its about the size of a pen nib.
2.) straighter out a paper clip
3.) insert the paper clip into the hole and push hard
4.) the drive will pop open, pull the draw out
5.) remove the disk
6.) push the draw back in firmly until its fully closed
on Jul 16, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Ts-h542a does it write to dual layer dvds?
Samsung TS-H542A DVD±RW Burner does not support Dual Layer Discs.
Dec 29, 2010 | Samsung TS-H542A DVD±RW Burner
Have toshibsamsung dvd+r/rw ts-h552b to replace cd rom in 3yr E-machine. Need software drivers?
You will need drivers to write DVD's. You can try Ashampoo's Burning Studio Free (link below)
Feb 04, 2010 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Dual layer?
NEC DVD + - RW ND-6650A is supprot dual layer dvd. for more information u can use this link: NEC DVD + - RW ND-6650A
Thank for asking
Jul 09, 2008 | NEC ND-6500A DVD±RW Dual Layer Burner
Noisy DVD/RW rom
My only suggestion is with Dvd driver
Jul 03, 2008 | Samsung (TS-H552B) DVD±RW Dual Layer...
Maybe your dvd's are pirated.. some dvd only plays original dvd.
Jan 13, 2008 | LG GSA-2166D DVD RW Dual Layer Burner
Samsung dvd rw
Uninstall Media Player 11 if the problem goes away and things are back to normal reinstall Media player 11 if it starts again. THATS A DRIVER PROBLEM. Ask microsoft to help they made the Media 11.
Aug 20, 2007 | Samsung (TS-H552B) DVD±RW Dual Layer...
Samsung (TS-H552B) DVD&#177;RW Dual Layer Burner Logo
125 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
