Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Vacuum is burning through the belt.
I have replaced my Eureka Altima Belt (with style U) and when I turn the vacuum on to use it, it immediately burns through the brand new belt and therefore does not work. I have tried three separate belts, but it does this each time.
  • Anonymous Jul 17, 2008
    July 17, 2008
    I HAVE THE SAME PROBLEM!!!! That is exactly what happens to me - the belt burns up - I have gone thru 2 of them so far.....
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=789867
Posted by slhb on Jul 16, 2008
I have replaced my Eureka Ultima Belt (with style U) and when I turn the vacuum on to use it, it immediately burns through the brand new belt and therefore does not work. I have tried three separate belts, but it does this each time.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. According to what you have said I can see maybe 2 problems, either your brushroll or bearings are froze up or you have a build up of thread and hair on the bearing ends. The brushroll should be free spinning or #2. Your motor and pulley could be bound up and or shot and might need replacement. Check to see if the motor pulley spins freely and if it does then it almost has to be the brushroll and would need rebuilding or replacement. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 16, 2008
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
When i vacuum it smells and so i turn it off. the
The belt is probably worn and slipping, that is why it smells. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 17, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Eureka Altima vacuum. The model number is 2996. I don't think my vacumm is sucking any dust. Plus, it smells like a burning leather. What should I do? I have tried to get help from others and they...
Sounds like the belt for sure. Here is a link with the owners manual. It shows how to get to and change the belt.
http://www.eureka.com/index.php?option=com_productdisplay&view=productdisplay&task=getproducts&productid=2&product_model=2991AVZ
Sep 18, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Bagless Upright Brush is not spinning
You probably just have a broken belt. The belt needs to be changed about every 6 months regardless. I believe yours takes a style EXT U(Extended life upright), or a regular Eureka "U" belt works fine too.
Nov 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
145 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
