Question about Philips 55P8341 55" Rear Projection Television
I need a blueprint/direction please!!!!
I have the sam problem as well as when the tv would turn on the picture came in concave.I read the solution below and would like to know how to locate these and to test 5 volt protection is causing the set to go into protective shutdown. Check for shorted diode 6306. Part#934038020127
or shorted capacitor 2318. or faulty voltage regulator
  • Philips Master
  • 8,617 Answers
Phillips is a hard set to troubleshoot without the full service manual and schematics and with a good understanding of testing voltages. It may be easier to replace the LSB for your model. If you need more info on where to get a manual or LSB let me know and I will assist you.
Posted on Jul 16, 2008
Blue vertical lines on tv when turned on....now no picturs.
the guns gone bad inside needs to be replaced.
Apr 22, 2009 | Televison & Video
Picture is concaved and all the colors are off.
you will need to get a convergence done and the resistors on the conversion IC's checked and bad ones replaced
electech
Oct 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
No picture no power red button flashes 4-5 times and shuts off
Try unplugging the 3 convergence yoke plugs and then trying to power on the set. The convergence plugs are located on the board on the left side of the tv looking in from the back and they are 3 identical plugs right next to each other they have a R B and G next to the plugs one letter for each plug just remember which plug goes to which location when you plug them back in.
Jul 16, 2008 | Philips 55P8341 55" Rear Projection...
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
Concave picture
more then likely your convergence ic's have bad solider connection and need to be resolidered hope this helps
Oct 16, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Philips 55P8341 55" Rear Projection Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
