Question about GE PSS26SHRSS Side by Side Refrigerator
My ge profile side by side bottom freezer is hot to the touch
I had an electrical power surge the other day and ever since my refridgerator has not been cooling properly. The freezer has warmed up to 17 degrees and the refridgerator has warmed up to 40. the outside of the refriderator is hot to the touch near the bottom. I put fans near the bottom and this seems to help. I have turned the controls to 10 for the freezer and 37 for the fridge and it's holding. But the outside is still warm to the touch while the fans are still running.
  • 700 Answers
Is you condenser fan runnig at all. look in the back ot the unit and if you have a cover plate hten you need to either put your hand close to the opening and feel if there is a draft or if ther is air being blown out that is warm. If not then the condenser fan may be toast.
Posted on Dec 21, 2008
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Our GE Refridgerator has a glowing pink light in the freezer bottom part. What happened?
THIS IS THE DEFROST HEATER.
IT IS ONLY ON FOR UP TO 20 MINUTES 2 OR THREE TIMES A DAY. DONT TRY TO TOUCH IT, IT IS VERY HOT
Jul 06, 2009 | Freezers
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Not cooling at all
refridgerator not cooling making clicking noise from back
May 03, 2009 | GE Profile Stainless Bottom-Freezer...
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
I have ice forming in the bottom of my freezer section of my GE Profile side by side refridgerator.
probably have a clogged drain at the rear base of the freezer unit check at the very bottom of your freezer at the back look and see if the drain is covered with ice..
Jan 15, 2009 | Refrigerators
Hot high side assembly and at the front door section
Replaced the GE fan motor which seems to have solved the problem.
Dec 28, 2008 | Kenmore Refrigerators
GE Profile TFX27PF/TFT27PF Refridgerator
There is a line from the defroster catch pan, up under the freezer, to an evaporation pan, down under the bottom. If it becomes clogged with dirt, bugs, whatever, the catch pan will overflow, and leave a puddle on the floor. Find it and unclog it.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSS26SHRSS Side by Side Refrigerator Logo
294 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
