Question about Mitel 5220 IP Phone
Mitel 5224 keeps flashing message but is no message
Mitel 5224 keeps flashing message ,but is no message
  • dumbyhead May 11, 2010
    When you hit the message key does it said what left you a message(ext,etc)? What PBX system do you have. Embedded Voicemail or a third party VM system?
  • 37 Answers
This sounds like you have a call back message active on your phone, The callback is a through back to the days before we had Voice-mail, if you wanted a person to call you back you could activate their message light by pressing your message key while the called phone was ringing. To remove the light you would lift your handset and press the message key then select which party you wished to "callback", once the call was answered at the other end the light would be extinguished. Give this a try, I bet you will be surprised at the results.
Posted on Oct 14, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
If you hit the message key it says what left the message. If it is Voicemail lighting the lite you need the msg. canel code. Sometimes you need to delete ext and rebuild it.
Posted on May 14, 2009
  • dumbyhead Jun 23, 2009
    Callback Message.
4 Suggested Answers
SOURCE: Message LED keeps flashing even if there are no more messages.
Is the phone in a ACD? I'm guessing it also has a broken dial tone? We had this problem and found that the phone was part of an ACD but wasn't logged in, causing a call forward to kick in. We had to dial *81 on the phone to clear the phone settings (it will be different for you no doubt so check the Feature Access Code Assignment.
Failing this, I would suggest you take the persons telephone line out of the system entirely, clear voicemail, clear the extension number and clear its IP registration etc and then start afresh; this has worked for us in the past too.
Best of luck!
Posted on Dec 13, 2007
  • 378 Answers
SOURCE: how do i manually configure
Press and hold the up arrow.
Configure Phone - Yes
network parameters - yes
press no until you see "change" and press yes.
You will need to set the following appropriately.
IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Use with caution,
Mark
Posted on Apr 04, 2011
  • 378 Answers
SOURCE: What is the pinout for the headset port of the
No idea. Contact Plantronics for a headset. This phone will support a variety of headsets. www.plantronics.com.
Posted on May 01, 2011
How do I clear a Mitel 5224 which is displaying locked out
Set type is wrong or the phone is a IP device only
Jan 14, 2013 | Mitel 5224 IP Phone
How to delete messages without an account code
Need to login to the phone systems and reset it
Sep 13, 2012 | Mitel 5224 IP Phone
How to set time on a mitel 5224 phone
Need to get access to the phone system to change the time
Nov 02, 2011 | Mitel 5224 IP Phone
I want to change the voice message on my mailbox. I have a Mitel 5224 IT Phone. I hit the envelope and it says "NO MESSAGES". How do I record the message?
the envelope button only works when it is flashing. Need to dial the voicemail or if there is a key programmed on the phone that rings voicemail.
Jun 09, 2011 | Mitel 5220 IP Phone
How can we reset the voicemail password, on a Mitel 5224, for a new employee? We do not know the current password that was left by a former employee.
Contact your System Administrator or System Vendor. That is the only way to reset a password on the system.
Nov 12, 2010 | Mitel 5224 IP Phone
Hi =) I have a mitel 5224 which i connect to my
the stand requires configuration to tell it how to connect to your Wireless router. The default IP address is 192.168.1.20
The firmware should be upgraded to 2.0.3.ap51. This provides for better security and more options.
Nov 09, 2010 | Mitel 5224 IP Phone
What is the pinout for the headset port of the mitel 5224 IP phone?
Mar 04, 2010 | Mitel 5224 IP Phone
MITEL 5224-how do you set up your voicemail??
I have this phone at work. There's a button that looks like an envelope. Touch that and it will prompt you through recording your voice mail. This phone also features various "away" messages so that you can record a couple different ones and then activate whichever you want depending on your day. This is also accessed through the voicemail button. Once you play around with it a little, you'll find it's a rather simple phone. Right now, I'm trying to figure out how to access my voicemail from home! Good luck!
Sep 02, 2008 | Mitel 5220 IP Phone
Mitel 5220 IP Phone Logo
4,120 people viewed this question
Top Mitel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
rey francis basa
rey francis basa
danoyachtcap
danoyachtcap
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
