2001 Ford F150 Styleside SuperCrew Logo
Posted on Jan 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi... I have a 2003 ford windstar I to find the fuse for cigarette lighter doesn't work. I need to know which fuse on the fuse box. Thanks
Anonymous
Level 2:
Champion:
New Friend:
  • Expert 215 Answers
  • Posted on Jan 20, 2011
Anonymous
Expert
Level 2:
Champion:
New Friend:
Answers
215
Questions
0
Helped
40747
Points
441
It would say lighter or radio under the dash board,its will be a 20 amp fuse you will see it.
Which no. 2003 ford windstar Passenger Seat cigarette lighter fuse?
In the central junction box
fuse's
F 2.17 - 20 amp. cigar lighter front
F 2.5 - 20 amp power point console 1
F 2.15 - 20 amp power point console 2
Need help locating fuses for cigarette lighters (2) in fuse panel for 2003 Ford F350 Diesel
https://s1.postimg.org/51pg7vrf67/fuse_12.jpg
Click on the link. Interior fuse box, fuse 12 in the picture. Voltage for front cigar lighter and obd2 pin 16.
2answers
Penny dropped into the cigarette lighter of my 2008 saturn astra. I got the penny out, but the cigarette lighter doesn't work
hi,
there must have been a weak connection somewhere in the line.
use a volt meter to trace from the lighter to the fuse box.
I have also seen the wire connection go bad during a short in the back of the fuse box itself where the wire goes in.
follow the 12 volts and you will find your problem.
chris...
1helpful
2answers
Hi I have a ford focus tdci 2003 and the cigarette light has stopped working and i am presuming it is the fuse. I have located the fuse box "hidden" behind the glove box but the fuses only has a...
The fuse box you are looking for, should be located in the driver's 'kick panel', down in the footwell area (to the left of the brake pedal). When you remove the fuse box cover, the fuse descriptions should be printed on the back of the cover.
You may have found a Junction fuse box, which is usually for relays etc.
Cheers,
"If this has helped you solve your problem, please rate this solution with thumbs up"
What does fuse #5 on and ford windstar do. It say it is a i/p power point.
This fuse protects the wiring to the power point only. The cigarette lighter is on a different fuse.Here is a break down of the circuit. If you need anything else,drop me a line. Thanks,Chuckb31943c.gif
2answers
No connection of OBD port
What do you mean it wont connect, it plugs in right?
it wont power up???? I'll bet the cigarette lighter is also dead, replace the lighter fuse
8helpful
3answers
Need to change the fuse of the cigarette lighter in my 53 Ford Focus C-Max
For the cigarette lighter fuse on uk models ford focus there is another 'hidden' fuse box behind the glove box.
Just unscrew three screws at the hinge of the glove box.
Replace fuse 35 which is a 15amp fuse.
Hope this helps .
1helpful
3answers
Can not find the fuse for cigarette lighter
Cigarette lighter does not work in my 2002 Ford Focus - checked the fuse box under the dash and unable to find a bad fuse?
7helpful
3answers
Fuse for 1999/2000 ford focus diesel estate cigarette lighter
its fuse 46 and it should be a 15 amp according to the manual as i have the same car as you hope this helps
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
