Question about Panasonic Lumix DMC-LC80 Digital Camera
"turn camera off then on again" message
When I do this, the camera continues to flash same message. Then goes dead. Tried replacing the batteries, using a new set and an old recharged set. I am able to take one picture, then the message appears again. This time the camera would not work, just kept flashing same message:  turn camera off then on again. Put Camera away. Two weeks later I turn it on and now it works. What happened?
  • Anonymous Dec 31, 2008
    i have the same problem ( please turn camera off an on again) an put new battries
  • Anonymous Apr 27, 2009
    I have same problem and have left camera off for long periods in the hope that problem will resolve itself but it hasnt..........has a solution/fix been found yet or is this a futile search for a solution.
    Mark Paul
Tried new batterys
Posted on Dec 31, 2008
  • Panasonic Master
  • 2,794 Answers
There could be a short in the battery contacts in your camera. You should inspect them for corrosion or oxidation.
Posted on Jul 16, 2008
I dropped my camera in a shallow bowl of water, and took the battery and card out straight away and left it to dry out overnight. I've tried it again today, and its taking photos again, and the lcd...
1. The best thing to do is to factory reset the camera to be sure everything
is in the default setting. Look in the manual or menu to RESET the camera.
2. If this does not work, you can try is to remove the battery and wait a day,
then put the battery into the camera again and recheck.
3. If that does not help either, your camera might need repair/maintenance.
Sep 03, 2011 | Olympus EVOLT E-410 Digital Camera
I have a Nikon Coolpix L22. I was taking a picture and all of a sudden I got a lens error message. now, yhe camera is totally dead.
If the camera will not turn on, you probably have a bad battery. Replace the battery with a new one and try again. It is possible that the battery was almost dead when the lens tried to adjust and this may have caused the lens error message before the battery completely died out. Else you will need to send the camera in for repairs.
Aug 03, 2011 | Cameras
My 2005 Dodge Dakota's alarm won't disengage. I have tried disconnecting the battery and everytime I connect it it goes off again. The truck will not turn over. The battery is not dead and the lights flash...
I just encountered this exact problem tonight. The engine will start, but the alarm continues until I disconnect the battery. Nothing else works. Have you found any solutions, zenythe?
Jan 10, 2011 | 2005 Dodge Dakota
My Canon EOS Rebel XS 35mm SLR Camera will not turn on. I took several photo's and then the camera stopped taking photos and just read "busy" thru the viewfinder. I turned the camera off and then it...
Your camera is 20+ years old. They are electronic and most likely it is dead. Clean your battery contacts. If that does not do it... again it's a 20+ year old camera. The electronics go, just like a dead tablet or computer, a bad transistor will kill the camera. You can buy used Rebels for dirt cheap, under $50. But again, you are buying an old camera.
Mar 24, 2017 | Canon EOS Rebel X 35mm SLR Camera
I can only take a few pictures on my camera before it either shuts itself off and/or won't turn on again. When I try to turn it on the red light flashes but the lens doesn't extend, and then the light...
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Oct 27, 2009 | Kodak EasyShare C330 Digital Camera
When the battery is connected and i connect the adapter, the laptop switches off immediately and the power led goes yellow and starts flashing 8 times then stops and flashes another 8 times.the sequence...
have you tried powering up without a battery installed? if not give that a go as i think the battery is faulty or dead if it still does not work your power adapter needs replacing
Aug 06, 2009 | Toshiba PORTEGE R500-S5007V U7700 1.33G...
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Camera will turn on and then turn off, while screen continuously flashes
I have had this problem with both a DSC-P72 and a DSC-P92 (same camera but 5 Mega pixel1.gif) They do need real good batteries, when the camera shut’s down I can run MP31.gif players or flashlights with those batteries for quit a while before those devices are dead.
I was traveling overseas once and installed “fresh” carbon batteries and the camera wouldn’t work at all. I had no photos on that trip until I found some alkaline batteries.
I even have bought 2 “dead” cameras1.gif to find that they work fine with REALLY GOOD batteries. So try it again before dumping the camera.
Feb 14, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
The flash isn't working
might be obvious, but try replacing the batteries. also during continuous shot mode, flash will be automatically set to off. otherwise contact samsung for repair estimate. Good luck
Mar 13, 2006 | Samsung Digimax A6 Digital Camera
Panasonic Lumix DMC-LC80 Digital Camera Logo
132 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
