Question about Intel Motherboard
M3plugin.dll i will like to know what this is an what it does to my pc an how can i fix it please thank you
  • 2,794 Answers
It's been reported as malicious software. It appears to be part of My Web Search as a plug in.
You can try getting rid of it by using an antivirus program that gets rid of potentially unwanted programs.
Microsoft.com has one available for free called Windows Defender. It's available for download at this link
Posted on Jul 16, 2008
When i startup my laptop i get massage that i lost m3plugin
Windows errors related to m3plugin.dll?
If Windows is unable to run applications due to a .dll error, this .dll may be missing or you may have registry error. Such errors can heavily influence the performance of your PC. I strongly recommend that you run this free registry scan.
Here you can download m3plugin.dll free of charge. The file is compressed so you need an unzip software in order to use the file. We recommend you to read the tutorial how to unzip and install the files. Use the link below to start downloading m3plugin.dll.
arrow_w.gif Recommended: Fix m3plugin.dll Errors arrow_w.gif Enhance your PC-speed: Free Performance Scan arrow_w.gif File description: MyWebSearch Idle Monitor, v. 1.0.3.2 arrow_w.gif Filesize to download: 2.4 kb
download_icon.gif Click here to go to the download of m3plugin.dll
Jun 09, 2009 | Intel Motherboard
@ start error message C:\PROGRA~1MYWEBS~1\bar\6.bin\M3PLUGIN.DLL
It seems this dll files is set to load at start up and would actually seem a virus of some sort, nevertheless, this file is not necessary and should be removed from the system and is already removed, all you need to do is disable this file to load at start up follow these steps:
Start>>>Run>>type msconfig>>go to the start up tab and look for the entry that is loading the dll file on startup>>uncheck the entry click apply then click close, restart the pc and the error message should not pop-up anymore.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 31, 2009 | Microsoft Windows XP Professional for PC
M3Plugin.DLL
Hi Bry, this is so common with, my web search program.
Try this. Right click once on the start button, (A pop-up window will open), slide up to Explorer & left click on it once. Right click once on the C:\ drive & left click Search from the list.
In the search top window type the name of the file: m3plugin.dll
Click search.
Windows will find the file. Right click once on the file m3plugin.dll listed in the right hand side of the search window & left click Copy from the list. Windows Explorer is still opened. Scroll down to the folder, Program Files & left click the plus sign next to it. Program Files will open & you'll see all kinds of folders.
Find the Mywebsearch folder & open it. Find the folder 1.bin, Right click once on that folder & left click past from the list.
Close all opened windows & restart the system.
Enjoy Bry!
Please vote!
Mike
Nov 24, 2008 | Intel Motherboard
M3plugin.dll
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-7
Oct 30, 2008 | Mercury P4VM800M7 Motherboard
M3plugin.dll
This is a Spyware issue. Go to Add/Rmove in the Control Panel and remove from the list. Then You have to update and run your Anti-virus program. Then google Ad-aware 2008 and download it and install. run it to clear the spyware. The google CCleaner , d/l it and install it when it opens click on analyze , then run cleaner when it finishes analyzing.
I would download SpyBlaster 4.0 ( or latest one) and install it
Try to run the programs in Safe Mode.
These are all free programs that will help you clean your PC and help keep it clean.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 15, 2008 | Dell Dimension 2400 PC Desktop
C:progra~1\mywebs~1\bar\4.bin\m3plugin.dll
delet this virus
D:\PROGRA-1\MYWEBS-1\bar\1.bin\M3PLUGIN.DLL
Oct 12, 2008 | Microsoft Windows XP Professional
M3plugins
(This is very specific). For Windows XP.
Right click once on the start button & slide up to & left click on search. In the search windows under, All or part of the file name: type in m3plugin.dll
Than under, Look in: click the drop down menu & click on C: Click search. Once the file is found right click on it once & slide to & left click copy. Right click once on the start button, slide up to & left click on Explorer. Left click on the + sign next to Program Files. Left click the + sign next to MyWebSearch. Left click the + sign next to Bar. Right click once on the 1.bin folder & slide to & left click past. The m3plugin.dll file will than be copied into the correct folder. Re-start you're PC.
Mywebsearch help link: http://help.mywebsearch.com/sbar2.html
Things you should know about the program:
http://www.emsisoft.com/en/malware/?Adware.Win32.MyWebSearch+Toolbar
Fix 2# If you no longer have the mywebs free screensaver program and your still getting this error message simply go to run, type in MSCONFIG and go to, startup & uncheck the link that says c:\progra~1\mywebs~1\bar\1.bin\m3plugin.dll. Click apply than OK & let windows restart.
If this does not correct the error message post your findings.
If this fixed your troubles great. Please vote.
Mike
Aug 24, 2008 | Intel Motherboard
M3plugin.dll
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.
pentium iii windows XP
the specified module could not be found m3plugin.dll it appears on startup on windows xp and i want to fix it
Jul 28, 2008 | Intel Motherboard
M3PLUGIN.DLL
Error loading
C:\PROGRA~1\MYWEBS~1\BAR\1.bin\M3PLUGIN.DLL
The specific module could not be found.
please solf this problem
Jul 16, 2008 | Intel Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
