Typing error Hay There! Um, i entered the key and insallation went successfully but now i cnt seem to be able to type anything as i press the keys on my keybord nothin happens. Would this be a problemn in my settings of some sort or something else? Cheerz
    Novelist:
    Scholar:
  • 160 Answers
If you have a USB keyboard, you may need to go into the BIOS and look for "USB Keyboard Support". You'll probably need a wired keyboard to make this change.
But I'm curious - how did you type this message if your keyboard doesn't work? :)
Posted on Jul 18, 2008
I am trying to restore my laptop to factory settings coz I had a virus and as soon as i had pressed F10 after the Windows logo it is asking for a password. But I do not have one. Can you help?
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Computers & Internet
I want to set the clock on my keyboard and I do not know what button to push
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
Apr 15, 2011 | Logitech MX5500 Keyboard/Mouse
I am using win 7. Trying to install Microsoft Office Home and Student 2007. Receive message encountered error during setup. Error 25004.Config.Xml not specfied; a valid config.Xml file must be authorized...
This problem occurs if the previous install was unsuccessful or re installation. Follow these steps to resolve this issue:
  1. Pres Windows logo key + R. The following dialogue should open:b1011b9.jpg
  2. Type cmd as shown and press enter. Command prompt will open:9efcac2.jpg
  3. Type cd %allusersprofile%\Application Data\Microsoft Help, and then press ENTER; type EXACTLY as shown: cfda63e.jpg
  4. Type attrib -h rgstrtn.lck, and then press ENTER.
  5. Type del rgstrtn.lck, and then press ENTER.
  6. Type exit, and then press ENTER.
Note: You must have Administrator privileges or you cannot follow the above steps. Also the test you are directed to type in command promt must be EXACT or it will not work (note the spaces between commands).
After successfully completing the above with no errors, try installing Office again.
For your convenience, the Windows logo key is found as:
Mar 07, 2010 | Computers & Internet
Change to standard time?
Nov 03, 2008 | Logitech Cordless Desktop MX3200 Laser...
Unregistered, registering a new base, faillure....
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
Jun 22, 2008 | Philips VOIP8411B/37 IP Phone
Need instructions for change time on Logitech MX3200 wireless keyboard
Mar 17, 2008 | Logitech Wireless Access Duo Optical...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
