Question about Denon AVR-1804 Receiver
No display; No power
I tried turning on the Denon AVR 1804 one day and I had no display and no power. I performed the microprocessor reset procedure with no luck. Then, I opened it up and found the fuse in the bottom was blown...so I replaced it, retried microprocessor reset and tried powering up again. Blew the fuse again. Any suggestions?
  • dippy0 Jul 19, 2008
    Thanks Dan,
    I have a local "Denon certified" repair shop nearby. Would this be necessary? Or would any old shop do? It cost's 40 bucks for the certified shop to tell me what's wrong. If I chose for them to fix it, the 40 bucks goes to the repair.
    Mike
    Thanks again.
    Mike
  • 4,234 Answers
Your unit has a hard short in it. This is usually a power supply problem. Most likely the rectifier has failed. This should be a relatively simple and inexpensive repair. Figure on $10 for parts plus the local labor rate.
Dan
Posted on Jul 16, 2008
  • ABRsvcs Jul 19, 2008
    ANy shop should be able to repair this. I work on many brands without being a "certified" servicer. The certification becomes necessary when warranty work is required. Also, many shops that are authorized service centers must demonstrate ability and quality. I've been doing this too long to worry about certification. Check around. Reputation is worth more than certification.
    Dan
Denon avr-1804 no power
Mr Paul.. Thanks ur valuable information . I got a unit and it had one power transistor gone. even after replace not work but I follow ur instruction done. Appriciate.
Apr 04, 2014 | Denon AVR-1804 Receiver
How do I restore factory defaults on my Denon AVR-2809? I can't see it in the manual. Thanks
Register and download the USER GUIDE (10.6MB) for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-2809CI-Receivers-manual/id/21864dj590/t/2/
Page 60
Resetting the Microprocessor
Perform this procedure if the display is abnormal or if operations cannot be performed.
When the microprocessor is reset, all the settings are reset to their default values.
1 Turn off the power using <POWER>.
2 Press <POWER> while simultaneously pressing
<STANDARD> and <DSP SIMULATION>.
3 Once the display starts flashing at intervals of about 1
second, release the two buttons.
Mar 30, 2011 | Denon Audio Players & Recorders
My Denon AVR-1804/884 standby light stays on but the receiver wil not power up
ok my denon avr 1804 was jamming and it shut off on standby red light flashing comes on then goes back off what is wrong ?????
Feb 27, 2011 | Audio Players & Recorders
How to reset the protector circuit in a Denon AVR 3801 unit?
14 INITIALIZATION OF THE MICROPROCESSOR
When the indication of the display is not normal or when the operation of the unit does not shows the reasonable result, the initialization of the
microprocessor is required by the following procedure.
1 Switch off the unit and remove the AC cord from the wall
outlet.
2 Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet.
3 Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
NOTES:
• If step 3 does not work, start over from step 1.
• If the microprocessor has been reset, all the button settings are
reset to the default values (the values set upon shipment from
the factory).
• Calling out preset stations from the main unit‘s panel.
1 Press the TUNING PRESET button. TUNING
PRESET
FUNCTION 2 Turn the FUNCTION knob and
select the desired station.
TV CD CDR/MD/TAPE RECEIVER
VCR DBS/CABLE
SKIP
SKIP
ENTER
MEMORY
CHANNEL VOLUME
VDP DVD
TUNER PHONO CD
DISPLAY
SETUP RETURN
MENU
SHIFT
SURR.
PARA. OSD
A/B
MUTING
BAND MODE
TUNING
TUNING
2 1
(Main unit)
Jun 11, 2010 | Denon AVR-3802 Receiver
Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
Feb 23, 2010 | Denon AVR-1804 Receiver
How do I reset my Denon avr-589? I would like to reset my reciever back to original settings.
Press the power button, and speaker a and speaker b simultaneously and hold until the display begins to flash then release speaker A and speaker B buttons. That resets the microprocessor.
Jan 02, 2010 | Denon AVR-1508 Receiver
Denon avr-1804 its turns back after 5 sec
Disconnect all speaker wires on back and then turn on. If it happens again, it's most likely a power supply problem. If it doesn't happen again, it was probably crossed speaker wires.
Dec 28, 2009 | Denon AVR-1804 Receiver
Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Aug 20, 2009 | Denon AVR-1908
Denon AVR 1506
Try this, turn off the unit and remove the AC power cord from the electrical outlet, Hold the AUTO button and PCM button and plug the unit back into the electrical outlet, if the display starts flashing with 1 second intervals then release the 2 buttons, this initialized the microprocessor
Feb 09, 2009 | Denon AVR-1506 Receiver
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
Denon AVR-1804 Receiver Logo
677 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
