Question about HP LaserJet 1300 Printer
HP 1300 LJ Fuser Film
Hi ! I replaced the fuser film on my hp Laserjet 1300 and now it turns on but not print. then orange light blinks, what could be wrong? thanks!
  • certifiedtek Aug 25, 2008
    Replaced fuser film and yellow attention light just blinks no motor or gears turn. Did the engine test and triped interlock and front door switch nothing will turn. The only thing not sure of is exit sensor and the hp diagram poorly shows how it goes in. Ive been fixing printers for years but this has me stumped. HElP!!!!!!!
  • Anonymous Mar 30, 2014
    cooling fan not working
  • 138 Answers
If you didn't have the orange light to start with and were replacing the sleeve due to a torn or damaged sleeve it sounds like you haven't plugged everything back in. The Error is an electrical fault with the fuser circuit.
Verify that all wires are plugged back in. Two areas to pay specific attention to are as follows. (1.) BOTH slide clips witth wires that you removed on the upper fuser edges to mount the new sleeve. Thats the connections for the ceramic element. If you get to having to uninstall and check the fuser, put an ohm meter on both ends of the element to ensure it's not shorted. My meter when on ohms has a beep when the leads are touched together when the meter is measuring ohms. Check for the beep when touching both ends of the element and that will prove the element good.
(2) On the board in the base of the machine, there are some plug in connections on the lower board very close to the rear edge and just about centered left to right. It's a cluster of about 3 or 4. Unplug the connections and pay close attention to the height of the pins inside the connection. One of those connections has a nasty habit of the pins slidding through to the other side and not making good contact. If I remember right its the right hand connection in the cluster or the one next to the right one. You can use the connections rest to it as a visual referance for the height. If the pin or pins have pushed down, carefully pull them back up with needle nose pliers or tweezers and replug the connection back in.
Hope that helps you. Just in case, heres a free manual PDF link to use to resolve. It's a 1200 manual as the 1300 wasn't listed but the processes are identical. Most of the parts are the same but check first before ordering any parts.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%201200%20Series%20Service%20Manual.pdf
Posted on Aug 04, 2008
I have hp lj 1300 printer befor problem fuser sleeve damage that is repalacing and fixing but now not working only read light bilnking how can repair sir
red light blinking gnerally for
1.door open
2.no cartridge
3.fuser element blown( measure fuser element with volt meater)
4.sensor error
and so many
these are the mejor.
Jan 09, 2011 | HP LaserJet 1300 Printer
Hp printer laserjet 1300,its meking lots of nosien printing faintly,its also creasing papers
if the noise is like a plastic packaging its most likely the Fuser Fixing Film.
You can get it replaced at a tech with a compatible one or with a new fuser assembly.
Nov 18, 2010 | HP LaserJet 1300 Printer
1300 Printer prints roller marks only on one side. have tried cleaning roller & changing cartridge.
If it is not the cartridge check the fuser. Open the back access cover shine a light in and look for wear marks on the grey fuser film. If it is worn the fuser film is worn it should be replaced.
Jun 09, 2010 | HP LaserJet 1300 Printer
Paper wrinkles on left side when printing
Fuser is worn out (specifically, the pressure roller).
May 19, 2009 | HP LaserJet 1300 Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
Piece of plastic film when printing
yes. the fuser film sleeve is part of the fuser units.
Oct 06, 2008 | HP LaserJet 1012 Printer
Lj 1300 doesnt spin up just blinking bottom yellow light
My guess is that the wire from the photocell at the rear of the fuser (exit sensor) is not seated properly. The connector on the board side also has a nasty habit of the pins pushing down into the board in the connector. Put check the connections carefully from the exit sensor to the main boad. If it has pushed down, it can be pulled back up without ill effects using a small pair of hemostats..
Let me know what you find. Hope that helps you.
Aug 25, 2008 | HP LaserJet 1300 Printer
Fuser
You will only need the fuser unit. It is a little complicated but here it is. You need to remove all the covers, the several screws and a bracket. Here are some good directions.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%201150,%201300%20Service%20Manual.pdf
Jan 22, 2008 | HP LaserJet 1300 Printer
Hp 1300
the fuser is delaminated , you need a new fuser unit.
FIXED FILM
Where about are you in the world as you can buy the fuser unit and get it fitted. There is nothing you can do to repair the machine you will have to replace the fuser unit.
Please mail back
Thanks J
Jan 05, 2008 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
748 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
