No music I can't get my Technics SL 1200 m3d's to produce any sound.  I double checked all my connections and still nothing.  Any solutions???? Jeff
  • 515 Answers
Where do you have the turntable connected? Is it going into a DJ Mixer, a Receiver, or a Power Amp?
No matter the unit, make sure you have it plugged into the PHONO INPUT connection on the rear. If your receiver/amp does not have this, then you will need a PHONO PRE-AMP - The turntable connects to the PHONO PRE-AMP, and the PRE-AMP connects to the LINE IN or AUX IN of your receiver.
If you are connected to the PHONO INPUT of your mixer/receiver/amp, then the problem might be one of the following on the turntable:
1) Tonearm
2) RCA Cables
3) Cartridge
There is no easy way to see which one of these is the culprit, it's just a matter of elimination.
But, you didn't provide much information. If you can be more specific as to how you have your turntable connected, what kind of cartridge your using, and whether or not, you've determined that the problem is indeed the turntable and not your mixer/receiver/amp, or even your speakers. This would help in determining what the issue might be.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.DJPROLAB.com
Posted on Jul 16, 2008
Technics sl dz 1200 no vinyl play
is anybody have solution for this? i have the same prob...
Apr 11, 2012 | Panasonic Technics SL-DZ1200 Turntable
I was just giving a technics record player sl 1700 and for some reason I get sound out of the record but it does not hook up to my speakers. It has the red and white av cables and I have hooked all that up...
We need to know exactly what you have for electronics to give a specific answer.
Old-school turntables don't connect directly to speakers. It will require a PHONO preamplifier either integrated into a receiver or stand-alone and external to boost and frequency-balance the minute RIAA output signal produced by the phono cartridge.
Dec 13, 2010 | Technics Audio Players & Recorders
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
May 10, 2010 | Technics SL-1200 Turntable
I have a technic sl 1200 m3d with a broken tone arm, which arms are compatible?
HELLO
Have a look at Originlive on the net. They do an armboard which should fit your turntable easily and enable to put a Rega RB250 or RB300 arm on your machine - it will improve audio quality too!
Apr 29, 2010 | Technics SL-1200M3D Turntable
There is not a signal going from the turntable (technics 1200 m3d) to serato on my computer. when I analayze it there is nothing
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Jan 16, 2010 | Technics SL-1200M3D Turntable
Just bought a new technics sl-1200 turntable and the pitch speeds up and down causing music to sound funny....
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Dec 03, 2009 | Technics SL-1200 Turntable
Connection help
Nope. There are no input connections on the DZ1200. However, you can use programs like Serato, CUE, TRAKTOR, or PCDJ, and you can keep your music on your computer/hard drive, and control with the DZ1200 via specially coded CDs.
- OPTiC
DJ Pro Lab
1200s.com
Aug 16, 2008 | Technics SL-DZ1200 CD Player
279 people viewed this question
 Grubhead
Grubhead
