Question about GE Refrigerators
I own a GE side by side refrigerator Model GSS22KGPD WW, Serial AG225890. This the third frig of the same model with the same identical problem. The ice cube dispenser on the door only gives crushed ice when it's working at all. On the inside water drips into the ice bin and causes the ice cubes to fuse together so the auger can't work. I have a solid block of ice on the bottom of the tray. At present I daily empty the cubes, wash the tray and dry well and start over. I have had at least eight service calls on this problem and parts have been replaced, but the problem still exists. I recently spent $250 fixing the frig side and more parts for the ice maker. Nothing seems to work. This frig is approx 8 years old. The appliance store I dealt with replaced the first one with a second one and GE replaced the second one with a third one approx six years ago. The problem is getting worse and the serviceman from the appliance store does not seem to be able to find the problem. It has never worked correctly from Day #1 and it was a $1,000 frig. Why just crushed ice when working and why is water dripping into the tray freezing up the cubes and the auger.
  • Merch211 Jul 17, 2008
    I'm not sure everything the service person has done, but I will call this info to his attention. He is a certified GE tech, so I would hope he has checked all this out in the several times he has been here.
  • 481 Answers
  •  if the cubes that the icemaker makes are full size then... the water valve on the back of the machine is usually the culprit in these cases. it will not close fast enough resulting in a little overflow of water into the auger assembly every time it makes ice. it only takes a little bit of water to settle in the bottom of the pan to cause problems.
  • if the cubes are smaller than what you would expect then the water is leaking out right before it reaches the icemaker. either from the plastic tube behind the icemaker or the cup on the icemaker that funnels the water into the icemaker.
  • it also could be the timer inside the icemaker leaving the water valve on too long.
  • all these things can be tested on site. the service person must not be very well trained.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 16, 2008
Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Feb 03, 2010 | GE PFS22SISSS Stainless Steel French Door...
GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side ffreezer continues to frost over
A simple defrost may not be all that is needed. There is a piece that connects to the coils called a defrost timer or a " clixon " This is most likely the problem. Have it replaced and that should get you back in business. Hope this helps. Good luck.
Jul 09, 2009 | GE Refrigerators
GSS22KGPD WW G.E. side by side 21 Cub ft.
You beat me to an answer for you. the freeze up was most likely in the door. you may want to check with GE if my memory serves me corret there is a servie bulletin for this condition. thanks for using fixya Peyton....
Feb 17, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE side by side
I have a G E side by side refrigerator model #GSS201ephww and need a part for it . i can't find this model anywhere on the internet now . even on the web site given in the owners manual.. please help..
serial # is MG268486
Oct 15, 2008 | GE GSS20IEP Side by Side Refrigerator
Hot
check to see if the fan at the compressor is running
Jun 17, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE side by side frig: JSS22JEMC WW
sounds like defrost or fan problem let me know and I can help you
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
319 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
