Question about Sony Cyber-shot DSC-W80 Digital Camera
USB connecting problem
Whenever i m connecting my sony digital camera to any pc its showing switch on [menu] after this nothing is happening.please let me know the solution
  • tchambers08
    tchambers08 May 16, 2012
    I have the ver same problem with my DSC-S030, when i connect it to the computer it comes up with 'USB mode
    Connecting to mass storage' after 30 seconds or so it then come ups with a screen say 'USB Mode
    Connecting...
    Switch on [menu]'
    when i click menu it comes up with a choice between 'mass storge' or 'PictBridge'
Are you talking about when you connect the camera to the computer the viewfinder is blank? It should say "USB Mode Mass Storage" on the View finder. Should pop up on your computer. If not unplug it from the computer and shutoff camera, then restart computer. Then connect everything again. If not, I would then start by reinstalling the software. I really don't get your ?. You can't get to a menu when connected to the computer. It is just use to transfer pictures/video from your camera to computer if you don't have a Memory Stick Pro Duo slot on your computer.
Posted on Jul 17, 2008
I cannot show pictures on my tv from my sony 120 . I have the cords and the input on the tv but nothing happens when I try to show them???The manual suggest to delete the usb port???
You can either use the supplied A/V and USB Multi connector cable for connecting the Camera to the TV. Connect the Yellow cable to the Yellow port on the TV for Video and the Red and White for audio. Then select the proper input on the TV where the cable is connected.
You may also connect the HD Out of the Camera to the HDMI Input on the TV using the compatible HDMI cable for the Camera.
Before connecting the Camera to the TV, you may have to change the settings in the Camera depends on the TV type.
1. Component Settings from the Main Settings 2 Menu of the Camera should be set to HD or SD depends on the connection. Also depends on HDMI (HD) or A/V (SD) video connection.
2. Video Out Settings from the Main Settings 2 menu of the Camera should be set to NTSC or PAL depends upon the color system of the TV.
Try changing the settings in the Camera and connect it to the TV to view the images.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony camera says Switch on [MENU] when i upload pic from USB cord
1) Try uninstalling then re-installing your Sony software.
2) When you connect to the PC and switch on, Click on Start - "My Computer". Your hard drives and disk drives should appear in the window.
Have a good look, is there a new drive, it may be called Sony, or USB mass storage device it may just be called drive E or F.
If so double click on that drive, if there's a folder there, double click on there, with luck you should see your pictures, that new drive is really your camera.
You should be able to move pictures by copy and pasting. Once copied you can deleted them from your camera.
3) You can buy a device called a "Memory card reader" Make sure its good for sony memory sticks.
You take you card from you camera and put it in the card reader. Then, once plugged into a USB port its just like another HDD as described in 2.
4) I should have said this first, try another USB port if you can, it my just be dust in the port making life hard............
Good Luck.
May 08, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
How do I transfer 8mm & Hi8 tapes to DVD using my computer?
just go to this link:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV740&SelectOS=7
download the usb driver for your camcorder. install. Set power switch to Camera or VCR. Select USB Stream to ON in the menu settings. then connect camcorder to pc.
Mar 31, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
Sony Cyber-Shot DSC-P32 won't connect to computer
I think you have a wrong setting, go into the menu and go through it and it says USB connect or something to do with PAL/NTSB i don't have one in my hand.
Feb 21, 2009 | Sony Cyber-Shot DSC-P32 Digital Camera
I have a sont dcr trv120e cam corder .. when i plug it in pc nothing happens :(
Please install software "Picture Package" CD came with camera. Connect USB cable to camera and other end of cable to PC. Windows XP or Vista will recognize it and install its drivers automatically. If camera is not recognized by Windows, go to camera Menu, enable USB Streaming and check. Hope info will help you.
Regards,
Aug 20, 2008 | Sony Cameras
I can't load photos from my Sony Cyber-shot camera into my HP Pavilion a6110 computer using any of the slots or on front using the MS/PRP/Duo/PRO Duo
How are you connecting the camera to the PC? If you have Windows XP of Vista, You just need an USB cable, connect the camera and the computer will detect a new hardware and recommend which software you can use to open the pictures.
Aug 09, 2008 | Computers & Internet
USB problem
its the software designed in sony no one can change it
Jul 16, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Uploading pictures
Mass storage is easier, in my opinion. In that mode, when you hook the camera up to the computer, it will show up as a device in My Computer. Then you can just access your pictures there.
Jul 11, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
214 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
