My pirnter dosent print it says paper jammed but there is nothing jamed
    Master:
  • 848 Answers
Just clean print head and check whether roller is moving properly.....
provide us detail about your model for further help .....
Posted on Jul 16, 2008
It says my printer has a paper jam but i dont see no paper jamed and i refill it and it says say thing like it would let it go like its going to print then says jamed paper
Try and see if you can locate a small piece of paper that might be causing your printer to jam. Turn the rollers and see if you can see any small pieces of paper stuck in between the rollers.
Mar 02, 2011 | Canon Pixma iP2600 Photo InkJet Printer
My paper keeps going in crooked and jams
Hi, at the following link you will find some easy to follow steps on how to prevent this type of problems. Also make sure there is nothing blocking the path of the paper when the printer is trying to feed it. Sometimes objects will fell inside the printer and block the paper path thus causing the paper to be pulled from one side and the other jamming.
http://bit.ly/duaUlt
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
I am having a problem with paper jaming nothing seams to be in there but it tells me there is a paper jam
when turn on the status is ready? But when start printing status go paper jam? The problem is head, try to replace head.
Jun 10, 2009 | HP Photosmart 3310 Printer
PAPER JAM
open the front door and remove inkl cartridge then check thr is not any paper jam .thn refix the inkmcartridge.
Mar 12, 2009 | HP Deskjet 450 wbt Printer
Paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
My newly purchased X5340 shows a paper jam when there isn't one.
make sure you have taken all of the packing tapes off, and the paper tray is inserted correctly.
tunr off the pirnter and disconnected it from the computer. wait 5 min. turn on the printer and connect it to the computer.
Dec 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Printer says paper jam, but no paper in there
use a flash light check all paper path, specially the area around the toner. all you need is a small piece or other (dust). There is a micro switch that detect the paper travel. so if anything preventing the switch to open, you will get error message.
after that, open the toner door, reseat the toner and close the door. the pirnter should return to normal.
Oct 23, 2008 | Enlight Intel Xeon 470 WATT EN-470 MP...
HP OfficeJet 6110 All-In-One
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
