Sounds like a bad on/off (kill) switch. test the switch with a meter and if it is bad - replace the switch with a new one -- you should be able to find a new one at your local hardware store.
IF the switch is good then it could be a bad wire between the switch and the coil /mag. check wires and make sure all connections are good and tight.
c...
