Question about Lexmark Office Equipment & Supplies
MY lexmark printers keeps giveng me an error that the machine is jammed or out of paper but is not the paper even has the tendency to catch and go down at an angle and this is not letting me print anything
    Genius:
  • 2,035 Answers
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button.
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jul 16, 2008
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
I have a lexmark e238. Keeps showing paper jam light after cleaning rollers even though no paper is in there.
Either paper is moving too slow through the paper path or one of your paper path sensors is not registering. Pull the paper tray out and check to make sure the little plastic sensor is swinging free. That sensor tells when the tray is empty. Follow the paper path thru the printer checking all the sensors to make sure they are "opening" and "closing".
Apr 07, 2015 | Lexmark E238 Laser Printer
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Paper Jam light is on but no paper jam in printer?
Dec 17, 2009 | Lexmark E250d Laser Printer
Lexmark x7550 printer jam. I cleared the jam and hit the check mark button as directed, but it keeps looping through the paper jam sequence. It does not seem to register that the jam has cleared. If I...
There will be some form of error clear code that would need to be entered. It would be something like "holding down the print key and powering on the printer at the same time" The manual may tell you.
There are different combos for different manufacturers.
Nov 17, 2009 | Lexmark X7550 InkJet Printer
Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Lexmark X5495 Feeds paper in part of the way
I own this printer, it has to do with how you load the paper, it's very touchy, just keep readjusting the paper and you will get it right, you don't want the paper to far into the printer, or you will get a paper jam error, but if it's not in far enough it will sound like it's printing but not feeding the paper. Hope this helps, Julia
Dec 21, 2008 | Lexmark X5495 Printer
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
