Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Programming vehicle garage door opener on liftmaster "Formula 1"
The instruction manual said I should look for a "training button". I bought my home from a prior owner and I don't know where to find that button.
  • Anonymous Dec 07, 2008
    re-program remote key pad and car remote for a liftmaster professional formular 1 garadge door opener
  • Anonymous May 24, 2009
    I cannot find the training button
Simply go to the manufacturer's web site and it taught me how to locate the model number and eventually get me the full manual so I looked up the "training button" from the manual
Posted on Jul 16, 2008
The learn button is on the unit itself. open the plastic white light case. It is in there.
Posted on Aug 01, 2012
How do I get a manual for my garage door opener
Posted on Dec 19, 2008
I don't have the owner's manual for my 2002 GMC Yukon XL Denali. Do you know how to program the garage door opener?
I hope this helps.
Programming the HomeLink Transmitter
Do not use the HomeLink Transmitter with any garage
door opener that does not have the stop and reverse
feature. This includes any garage door opener model
manufactured before April 1, 1982.
Be sure that people and objects are clear of the garage
door you are programming.
It is recommended that a new battery be installed in
your hand-held transmitter for quicker and more
accurate transmission of the radio frequency.
Your vehicle's engine should be turned off while
programming the transmitter. Follow these steps to
program up to three channels:
1. Decide which one of the three channels (one of the
HomeLink buttons) you want to program.
2. Press and hold the desired button on HomeLink
through Step 3.
3. When the HomeLink indicator light begins to blink
slowly (this may take up to 30 seconds), hold the
hand-held transmitter about 1 to 3 inches (3 to 8 cm)
away from HomeLink and then press and hold the
transmit button on the hand-held transmitter.
Continue to hold both buttons until the indicator
light on HomeLink begins to flash rapidly (this may
take up to 90 seconds).
If you have trouble programming HomeLink, make
sure that you have followed the directions exactly as
described and that the battery in the hand-held
transmitter is not weak. If you still cannot program it,
move the hand-held transmitter to the left or right or
forward or backward or flip it upside down. HomeLink
may not work with older garage door openers that do
not meet current Federal Consumer Safety Standards.
If you cannot program the transmitter after repeated
attempts, refer to "Training a Garage Door Opener with
Rolling Codes" later in this section or contact the
manufacturer of HomeLink at 1-800-355-3515,
or on the internet at www.homelink.com.
Be sure to keep the original hand-held transmitter in
case you need to erase and reprogram HomeLink.
Training a Garage Door Opener with a
"Rolling Code" Feature (If Equipped)
If you have not previously programmed the hand-held
transmitter to HomeLink, see "Programming the
HomeLink Transmitter" listed previously. If you have
completed this programming already, you now need to
train the garage door opener motor head unit to
recognize HomeLink.
1. Find the "Learn" or "Smartbutton" on the garage
door opener motor head unit. The exact location and
color will vary by garage door opener brand. If you
have difficulty finding the Learn or Smart button,
refer to your garage door opener owner's manual or
contact the manufacturer of HomeLink at
1-800-355-3515, or on the internet at
www.homelink.com.
Because of the steps involved, it may be helpful
to have another person assist in programming
the transmitter.
2. Press the Learn or Smart button on the garage
door opener motor head unit. An indicator light will
begin to flash when the motor head unit enters the
training mode.
Following this step, you have 30 seconds to
start Step 3.
3. Return to HomeLink in your vehicle and firmly
press and release the programmed HomeLink button
three times.
The rolling-code garage door opener should now
recognize HomeLink. You may either use HomeLink
or the hand-held transmitter to open the garage door.
If after following these instructions, you still have
problems training the garage door opener, contact the
www.gmcextendedwarranty.com
Dec 19, 2010 | GMC Yukon XL Cars & Trucks
I have a liftmaster professional formula 1 and am trying to get the opener to sync with my car. is there a roaming setting on the unit that needs to be worked with in order to have it sync with my...
You have to first have your cars Homelink system learn your current remote (follow owners manual) THEN have the garage door opener learn the cars Homelink (push openers learn button then press the Homelink button you previously had learn your remote. Two learning steps required because the LiftMaster is a 'rolling code system'
Aug 07, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a quantum model 3212 serial #3000...fcc id #kj8intrmt...ok im trying to program my garage door to my truck..help please
1. In the vehicle press and hold the two outside buttons until the indicator light begins to flash (after 20 seconds). Release both buttons. Note: Some vehicles may require the ignition switch to be turned to the second (or "accessory") position during the programming process.
2. Hold the end of your handheld transmitter between 1 and 3 inches away from the Homelink surface (located on your visor or overhead console) keeping the indicator light in view.
3. Using both hands, simultaneously push the handheld transmitter button and the desired HomeLink button. DO NOT release the buttons until step 4 has been completed.
4. Hold down both buttons until the indicator light on the HomeLink Wireless Control System flashes, first slowly then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapidly flashing light indicates successful programming of the new frequency signal.)
To train your garage door opener.
1. Locate the smart/learn button on the garage door opener motor head unit.
2. Press and immediately release the smart/learn button.
Firmly press and release the programmed HomeLink button. Press and release the HomeLink button a second time to complete the training process. (Some garage door openers may require you to do this procedure a third time to complete the training.)
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
2005 hyundai accent 1.6L. car won't start
Hyundai TSB 08-BE-012
PROCEDURE:
1. For first time training, press and hold the two outer HomeLink buttons, releasing
only when the HomeLink indicator light begins to flash after 20 seconds.
NOTE: Do not perform this step when training the additional HomeLink buttons.
2. Position the hand-held transmitter 1-3 inches away from the HomeLink mirror,
keeping the HomeLink indicator light in view.
3. Using both hands, simultaneously press and hold both the desired HomeLink button
and the hand held transmitter button.
DO NOT release until the HomeLink indicator light flashes slowly and then rapidly.
When the indicator light flashes rapidly, both buttons may be released. The rapid
flashing indicates successful training and the procedure is complete. This also
indicates that the garage door opener does not use rolling code technology.
Note: The garage door may open or close during this step.
Steps 4 through 7 are only necessary if the HomeLink button appears to be
transmitting after step 3, but the garage door does not operate.
4. Press and hold the trained HomeLink button and observe the indicator light.
If the indicator light is solid/continuous, training is complete and your device should
activate when the HomeLink button is pressed and released.
If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light,
proceed with the following training instructions for a rolling code device. A second
person may make the following steps quicker and easier. It is recommended that a
ladder or similar device be used to obtain access to the motor housing. Do not stand
on the vehicle to perform the next steps.
5. At the garage door opener receiver (motor housing) in the garage, locate the “learn”
or “smart” button (usually near the hanging antenna wire attached to the unit). If
there is difficulty locating the training button, refer to the garage door opener’s
manual.
6. Press and release the “learn” or “smart” button (the name and color of the button
may vary by manufacturer).
NOTE: Once the button is pressed, there are 30 seconds in which to initiate the
next step.
7. Return to the vehicle and firmly press and hold the trained HomeLink button for two
seconds and release. Repeat the “press/hold/release” sequence up to 3 times to
complete the training process. If successful, your garage door should open or close
during this step.
If the vehicle owner continues to have difficulty programming their HomeLink mirror,
please have them contact HomeLink customer service directly at 1-800-355-3515 or
www.homelink.com for further assistance.
PROCEDURE COMPLETE
Dec 06, 2009 | 2005 Hyundai Accent
Liftmaster Professional and Clicker Programming Problems
The Security+ system is a rolling code system and is digital, so it will work with the Homelink in vehicles and with the remote control units that come with the opener. Also with new remotes that are purchased specifically for that opener. Your "clickers" require specific instructions and you need to use the Smart Learn function in order to use them with this opener. In addition, check the Brand Switch settings to be sure they apply to your opener, and the correct Smart Button color on the opener. Read carefully to determine whether you need to set ANY dip switches at all or can you just set them all to off depending on your opener? Check the instructions carefully. Here's a link to the page where you can download a copy of the Clicker instructions if you don't already have it:
. Clicker Model CLT1D Remote Control Owner Manual
May 14, 2009 | liftmaster Chamberlain Garage Door Opener...
Home link system program?
  1. Turn off the engine.
  2. Erase the factory test codes by pressing buttons 1 and 3. Release the buttons when the two green lights begin to flash (about 20 seconds ).
  3. Choose one of the three buttons to train. Position the end of your hand-held transmitter 1-3 inches (5-14 cm) away from the lower left corner of the EVIC display while keeping the display in view.
  4. Simultaneously press and hold both the desired Transmitter button and the hand-held transmitter button. After a short time, the message TRAINING will show on Transmitter display. Do not release the buttons until the message TRAINED appears on the display (this may take as long as 60 seconds ), release both the Transmitter and hand-held transmitter buttons.
  5. Press and hold the just-trained Transmitter button. TRANSMIT should appear on the display. If your device activates when the Transmitter button is depressed and released, programming is complete. To train the other buttons, repeat the process. Be sure to keep your hand-held transmitter in case you need to retrain the universal transmitter. NOTE: If the message TRANSMIT appears on the Transmitter display but your device does not activate, the device may be equipped with a "rolling code" system. Continue with steps six through eight below to complete the programming of a rolling code equipped device (most commonly a garage door opener).
  6. At the garage door opener receiver (motor-head unit) in the garage, locate the "learn" or "smart" button. This can usually be found where the hanging antenna wire is attached to the motor-head unit. Firmly press and release the "learn" or "smart" button. (The name and color of the button may vary by manufacturer.) NOTE: There are 30 seconds in which to initiate the next step.
  7. Return to the vehicle and firmly press, hold for two seconds and release the programmed Transmitter button. Repeat the "press/hold/release" sequence a second time, and, depending on the brand of the garage door opener (or other rolling code equipped device), repeat this sequence a third time to complete the programming process.
  8. Transmitter should now activate your rolling code equipped device. To program the remaining two buttons, simply repeat the process.
Dec 21, 2008 | Jeep Grand Cherokee Cars & Trucks
Change the code on a garage door transmitter?
There is a "learn" button on the garage door opener unit itself that you press before entering a code on the outside transmitter. This allows the receiver to learn a new code. The button is on the rear end of the housing near the terminals where the inside operation pushbutton connects.
Here's a link to programming instructions for a compatible unit by another manufacturer:
http://www.usdoorcontrol.com/instructions/liftmaster/keypads-66LM.pdf
Nov 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Jag xj6 1996 97 programming the garage door openers
1. For first time training, press and hold the two outer HomeLink buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.) 2. Position the hand-held transmitter 1-3 inches away from the HomeLink surface (located on your visor), keeping the HomeLink indicator light in view.
3. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
property_damage_symbol_sm.gif Note: Some garage door openers may require you to replace step 3 with the “cycling” procedure noted in the “View Canadian Instructions” section.
  • If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
  • If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the garage door opener’s manual or contact us. 6. Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step. 7. Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
Jun 13, 2008 | 1997 Jaguar XJ6
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
6,425 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
