Question about Microsoft Xbox 360 Console
Front panel doesnt work
I can only turn the console on and off by the controller and i also have to use a pin to open the disk drive has anybody got a clue how to fix would be much appreciated
  • joey2x4 Jul 16, 2008
    the games will come out its just that i cant operate the machine by the power button and the disk drive button does'nt work due to this problem any sollutions would be much appreciated
Hmmmmmmmmm i had the same problem for like 2- 4 weeks i couldnt open it and i was stuck playin uno lopl. The best thing to do is send it off or just hope that it will open again. Mine opened and now i never take cod4 out.
Posted on Jul 16, 2008
How I fix the xbox 360 controller blinking and sync light problem,when the sync button doesnt work?
My only guess would be that you disconnected the cable to the sensor while cleaning your Xbox. Have you checked all the connections before reassembling it? Check out the video I linked, maybe it'll help you!
Dec 16, 2014 | Microsoft Xbox 360 White Console
Dvd stuck in tv/dvd combo
There is sometimes a pin hole in the front of the device near the tray, you push something very slender into it and it opens the disc tray. If This doesnt have that feature, you may need to manually dissasemble to retrieve your disc.
Sep 20, 2012 | Sanyo Televison & Video
My disk trey does not open or close no matter what i do it doesnt want to open and when it does it doesnt want to read the disk what can u do fix it
this is caused by a problem in the mechanism and toothed gears that aid the movement of the drive.
most drives usually have a kind of pin-hole that you can use to reset the drives in case of issues like this but unfortunately, the xbox 360 has none so the best way out is to take it to a certified repairer and get it fixed. it shouldn't cost much. hope this helped you? please rate
Dec 18, 2010 | Microsoft Xbox 360 Console
Door will not open
make sure the drive is not reading a disk, because if its spinning it can break when you do this process.
look for a hole in the front of the drive, get a paper clip and stick it in there all the way, the tray will now eject or if its a slot loading drive the cd will eject
Sep 06, 2010 | Computers & Internet
I cant get my xbox to play any disks, i says 'reading' and then asks me to open the tray and very rarely reconises that there is a disk of any sort in there! ive tried cleaning the lens but that doesnt...
Clear the system cache:
1. On the console, go to My Xbox, and then select System Settings.
2. Select Memory.
3. Highlight any storage device, and then press Y on your controller.
4. Select Clear System Cache. If Clear System Cache is not available, use the following controller button sequence to clear the system cache: X, X, left bumper,right bumper, X, X Note If you don't see a system maintenance prompt on the screen, try pressing the button sequence again.
Try playing discs without the hard drive in:
1. Turn off your console.
2. Locate the hard drive on your console.
Press the release button on the hard drive and lift the hard drive from the console.
Turn on your console.
3. Try to play a game disc.
If this resolves the problem, you will need to replace the hard drive.If not, do the same thing for your memory units. If it works without them, the they may be bad.
Apr 02, 2010 | Microsoft Xbox 360 Console
XBOX 360 disk tray problems
you arnt gonna find a cd drive that will go easilly into it as they have codes in the boards on them that lock it to the xbox its in and it is quite completed to get the code out of it, can you tell how many lights are flashing on the front?
Jan 20, 2010 | Microsoft Xbox 360 Console
PS3 80 gigs 3 yrs old immediately turns off when you turn it on Has a rented disk in it any idea how i might get the disk out.
if u want to get disc out of drive take a "thin pin" which is thin enough to go in a small hole in the front panel of the drive...
while pressing the eject button...push this pin inside and you can get the disc out..
Jul 31, 2009 | Sony Playstation 3 (PS3) Console
Psp problem
if it doesnt read the disk,you may want to open it up (but voiding the warranty) and clean the UMD drive.
if it doesnt read just one UMD,it might be the disk.
if cleaning the UMD drive doesnt work,you may have to get a new drive,or a new psp.
Jul 25, 2008 | Sony PlayStation Portable (PSP) Console
Wii console
Im not familiar with the Wii but i will try to help.
Is it just not opening or is it actually physically Jamed?
If its jamed, try turning it upside down and then back to right side up, then try ejecting it.
There may be a pin hole on the front of the drive, just like a computer cd drive, get a thick paper clip and insert it, push hard till the drive pops slightly open, then pull it the rest of the way and remove the disk.
Last resort is to open her up and remove the disk drive altogether and then take apart the case, then you can use your finger to move the disk back onto the carasel and then eject it once its plugged back in.
Mar 25, 2008 | Nintendo Wii Console
The disk doesnt stay in
you are going to have to get a new drive. you can send it back to xbox if you have the warranty send it back, if not it is the drive and you have to get a new one. it will come out to about $130. the best case would be that you just busted a pin and hope they can replace the pin. connie
Jun 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
