Question about GE Profile Spacemaker Over-the-Range Microwave
GE Profile Spacemaker 2.0 Microwave
My GE Profile Spacemaker 2.0 Microwave I've had for one and a half years is now tripping the GFI it's connected to whenever I close the door. When I reset the GFI, I can run the fan and turn on the light. But I cannot cook anything either, even if I reset the GFI with the door closed.
  • GE Master
  • 9,086 Answers
If it goes dead or blows the breaker or GFI when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
GE Countertop Microwave Oven Door is stuck closed
Remove the cover. You should be able to access the two latches and release them. Once open you will have to take the door apart and repair the latch
May 05, 2014 | GE Profile Spacemaker Over-the-Range...
GE spacemaker XL microwave oven blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the house fuse or breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 26, 2012 | GE Profile Spacemaker XL 1800 36 in....
Ge spacemaker microwave, new, keeps tripping the GFI but keeps running
The first thing you need to check is the GFI--when it trips, it definitely should shut off power to the circuit. It may be wired incorrectly, or is faulty. There should be a 20 amp breaker and wiring to the oven.It is also much better is the oven is the only appliance on this circuit. Hope this helps!
May 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Active Vent opens and closes continuously while unit is idle
I had GE look at the problem today (my microwave is less than a year old and under warranty). He replaced the cam louver and that seems to have fixed the problem. This is a small motor accessible by removing three screws and the active vent door. The whole visit was less than 15 minutes.<!-- from fixya rte -->
May 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker XL JMV1460 Turns On by Itself
Sounds like there is a stray piece of wire or other metal floating around inside the case. Remove the cover and any breakables in the microwave (the power cord is unplugged for this), turn it upside down over a table and shake it, pound the bottom, and shake it some more--likely the offending piece will drop out onto the table. If so, put it back together and whack it to see if that fixed the problem (cord plugged back in). This process can be repeated.
Jul 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My daewoo microwave/toaster blew my breaker upon resetting it and plugging in the microwave it blew again then it tripped my GFI what could be the problem?
Probably a short inside the microwave circuitry.  I had a Daewoo and had nothing but trouble with it.  Main board went out in a year, then again in another year.  Finally went to Home Depot where I bought it and was told that they had nothing but trouble with them and quit selling them.  Now I have a GE Spacemaker.
Apr 22, 2009 | Microwave Ovens
Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
837 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
