I recently bought a slightly used 1200s from a friend. It was working fine
on his PC. When I set it up on mine, the B&W scans are Ok, but there is a
problem with the color scans. They all have thin cord-like vertical lines
through them. It is if the whole picture was painted on thin cords pressed
together. I tried different resolutions, and different descreen settings.
I removed the Umax UDS11 card and plugged the scanner into my main SCSI
card, PEL1600 (an Adaptec 1510 clone). I tried 3 different versions of
VistaScan and switching SCSI ID's. Nothing helps. I could not find any
info on this on Umax's web site. I vaguely remember reading of something
similar that was traceable to a SCSI problem. I have 1 other SCSI device on
the PEL 1600 and I am using passive terminators on both ends. Has anyone
encounteed this problem before? Thanks in advance!
R.
Rating: 0%, 0 votes
R
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
newspaper, magazine, etc) or electronic noise. If it's noise, try
moving the scanner from it's present location, if that doesn't work
perhaps you need a filter to clean up your power.
Peter
Digital Photography Reference
http://members.home.net/jonesp m/PJDigPhot.htm
Rating: 0%, 0 votes
might be dirt on the scanners calibration window (if tranny adapter) or
target (without tranny adapter). See umax's uk site for info on opening and
cleaning.
Post a New problem for Umax Astra 1200S Flatbed Scanner
Email this problem
Can you Help with these Scanners problems?
Umax Astra 1200S Scanner...
