Question about Kodak EasyShare DX6490 Digital Camera
Need to take apart DX6490
Having problem opening my DX6490. My wife fell and got sand in it and it won't work now. Looks like I got all the screws out -even under the rubber flaps. Still won't come apart. Side with memory card is loosest. Side with rubber flaps tight especially by the flash.
  • 2 more comments
  • chamberskb Jul 17, 2008
    I need to know how to pen the case of the Kodak DX6490. Every since it was dropped in the sand the lens will not extend and will not turn on. I went thru the Kodak site and they just say send it in.
    Well getting the back off was just the start- how do I get to the lens mechanism to clean it out? Anyone? I took out the screws in the card but there are so many cables attached and the card is still not completely lose.
    THe camera did not get wet she just fell in the sand with the camera on and when I tried to turn it off the it sounded like sand (very fine) in there and would not let me turn back on again or should say it tries but lens will not extend.
  • chamberskb Jul 19, 2008
    I have been able to get the back off but I can't get the first board out of the way.
    Scholar:
  • 101 Answers
Try prying it apart with a thick credit card or (i use an old sim card for things like this) some other plastic tool that you can pry with without messing up the case. Make sure and pop off anything that can be removed and see if there are screws that you have missed.
Posted on Jul 17, 2008
  • Jerrod J
    Jerrod J Jul 17, 2008
    I would recommend using some sort of electrical contact cleaner spray, you can get this at the hardware store or car parts store, this might provide enough pressure to blast the sand out without damaging any electronics in the camera. Did the camera get wet at all, or is the lens shutter / zoom just sticking closed?
  • Jerrod J
    In that case, just use the electrical contact cleaner, or bring it to a camera shop and they will be able to clean it for you. Just be careful if you clean it yourself because you don't want to push the sand farther inside where it will get on the internal optics and CCD. Personally I would bring it somewhere like Wolf camera, or a local camera repair place, just look in the phone book.
  • 1,183 Answers
As you told that , the camera fell on sand, Its highly unlikely the sand would inside the camera, because the camera case is air tight. There could be more to the camera problem then just sand.
Refer to the following link from the product manual
http://www.kodak.com/global/en/service/publications/urg00167toc.jhtml?chapsec=urg00167c10s1&pq-path=1600
Thanks
Proton
Posted on Jul 16, 2008
  • Mandeep  Singh
    Mandeep Singh Jul 16, 2008
    You can also use the guided help section aswell
    http://www.kodak.com/global/en/service/r...
  • Mandeep  Singh
    Mandeep Singh Jul 18, 2008
    Any luck opening the camera ,I tried a lot of resources to get you the picture on how to open it, but there ain't any.I talked to one of my camera guys and its best to get the same done through an authorised repair shop. They informed me the lens, would assembly has to dismantled precisely as it has lot of small componets attached to hit and require small screw drivers.
    Thanks
    proton
There is sand in the camera
Hello, Looks like you have two options: either try taking it apart yourself,which could be done, just be careful not to drop any screws. Once apart, you're going to carefully blow out the camera of sand. This will take a lot of patience. The other option is to send it out to get repaired.
http://support.nikonusa.com/app/answers/detail/a_id/336/kw/repair/session/L3RpbWUvMTI5NjQxMTEyNS9zaWQvVU1oLUdubGs%3D
Hope this Help
Jan 30, 2011 | Nikon Coolpix S203 Digital Camera
Lo longer steams
I just finished taking my wifes S3101 apart because of the same problem. I found the inlet and outlet hoses clear, so the problem had to be with the heater. I took the water side of the heater apart and found the outlet nipple clogged with dirt and sand. I live in VA Beach and my wife uses tap water. There was a lot of sand and dirt in the heater, so I cleaned all of that out, used a very small drill bit to clear the outlet nipple and then reassembled. It works fine now, and you will have to use distilled water if you want the unit to work for any period of time. The casing screws were a real pain to remove, so take your time.
Nov 30, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam not coming out
I just took my wifes S3101 apart and found both inlet and outlet hoses clear, but nothing coming out of the boiler. I took the water side of the heater apart and found the outlet nipple clogged with dirt and sand. I'm from VA Beach and my wife uses tap water. After cleaning out the water side of the heater I had to drill out the outlet nipple, it was that plugged. Anyway, after that, I reassembled and it works fine. By the way, removing the casing screws was a lot of fun (not).
A green screw came lose inside the blender. It
The green screw is a grounding screw and the blender will work fine with out it, but it should be grounded with the power cord ground wire secured to the ground screw. Check the other wiring, the ground screw is not why it doesn't work now.
(unless there is another screw involved. The power comes in and goes to the speed control switch)
Nov 08, 2009 | Vitamix Super 5000 Work Top Blender
My wife was cleaning the lint catcher and something fell inside of housing of the catcher. Is there any way to unscrew the dryer to get it out, or are we just out of luck? I don't want to start up this...
You should keep your hand grenades somewhere else! Remove the top (either screws in the back or control housing or push in each front corner with a thin putty knife to release the latches), and remove the screws on the insides of both front corners, then lift up to release the front panel. That should give you access to the blower housing and duct work. Retrieve whatever fell in and vacuum out all lint in the area while it is open. Be sure to wash the lint filter in hot water and detergent to get rid of fabric softener deposits which plug the filter screen. Check the drum bearings (either sliding pads or rollers) for wear. Replace if found to be in bad condition. Also, check the condition of the drum belt and replace it if it is cracked or breaking apart. You will need to access a lower rear panel to remove the belt from the motor and idler wheel. Hope this helps!
Oct 29, 2009 | Whirlpool Dryers
My camera Kodak DX6490 need to repair..
Know no solution, just, that is, what my camera did when it fell, the zoom lence was zoomed out, now it won't retract. Must have a crack also like yours. I took the back off and tried to see if any cables were loose, none were so I know it's in the front area of the camera. The zoom probably. My LCD screen doesn't come on either. But the camera it turns on and lights up the selection icon that I have it on. Did you get yours fixed? Sorry to post on the solution when not a solution. But, I didn't see a reply button, to type a regular reply.I did call the Kodak company and they said to buy another camera would be cheaper than getting mine sent to them to be fixed.
Aug 29, 2009 | Kodak EasyShare DX6490 Digital Camera
Mode dial on my Kodak DX6490 camera is hard to turn!
dissmantle the back case (watch for 1 hidden screw under rubber covers), lift plate on back of lcd screen, remove screw on back of dial, clean where it sits on both sides (most probably from a liquid spill...tea, coffee...) , apply some lube with a cottonbud ore a bit of tisue and rebuild.
hope this helps
stewart
Apr 04, 2009 | Kodak EasyShare DX6490 Digital Camera
Need to open dx6490
Hello, I work on these DX6940 cameras and can tell you that you are between a rock and a hard place when it comes to the small joystick.This is a major point of failure on these cameras and you will not find a good replacement unit, Chinese made low quality and no replacements available. You need two cameras to make one good one !!!
GOOD LUCK
Russell
Aug 07, 2008 | Kodak EasyShare DX6490 Digital Camera
Sand in camera
no need to take apart just power up and gently pull the lens out and vaccuum the sand out, camera now works perfectly
Nov 09, 2007 | Casio Exilim EX-Z57 Digital Camera
Dismantling procedure for camera
Oh how fun, yep when I dismantled one of my old dead kodak digital cams - same thing, I'd removed all the screws but still struggled to open it up. Yes, the body is also "snapped" together with a couple of fittings. And after much futzing & prying, yah me. Holds up 2 plastic halves & one former camera guts. Yea was a good camera, it had lived a long & happy life, even after the super cheapo battery compartment door fell off, um, after being dropped maybe.
Apr 28, 2007 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
158 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
