Unbalanced Light I just inherited a Speed Queen that worked perfectly before transport. I made sure not to jostle it around too much and I didn't lay it on its side but now that I have connected it, it doesn't work. As soon as I plug it in the unbalanced load light comes on and there is no way to start it. How can I fix it?
  • Escalista Jul 16, 2008
    I actually did some additional investigation and found that the arm bracket had just slipped of the lid switch causing the the circuit to be left open. I just got a screw driver and moved the arm back in lace and it works like a charm. Thanks a ton!
  • 177 Answers
The lid switch needs to be reset. You may have bent the switch arm bracket while transporting it.
You will need to find the Speed Queen model number then go to or and look for repair parts.
Posted on Jul 16, 2008
Speed queen dances all over. Top I loader
Your load is unbalanced. Resitribute the wet clothes more evenly. If its a new installation, did you remember to remove the shipping locks from the back of the unit before using it?
Aug 30, 2014 | Washing Machines
My speed queen wash properly it drain properly but when it come to spin it go very very slow and it make like jurking movements
Some times the clothing will be piled up mostly at one side of the drum after the completion of the washing/draining cycle. This is normal. When the drum starts spinning/rotating to dry the clothing it is unbalanced and the drum will then not reach high speed due its banging against the outer casing which will also cause the jurking movement. Rearrange the clothing inside the drum by spreading it evenly around the agitator. If this does not solve the problem the machine might be seriously overloaded ( too much clothing). Take some clothing out and see if its is better. If it still persist then open up the front panel by unscrewing the three screws at the bottom of the panel and lifting the panel up and out. Please disconnect the electrical power supply first. Look inside the machine for the van belt between the electric motor and the big pulley underneath the drum. Check the condition of this belt as it might need to be replaced. ( badly worn over all, inner rubber area cracked badly, rough sides ect). TAKE NOTE: Replace with genuine Speed Queen part as a normal vehicle v-belt will not work. Pressing against the belt will be a small pulley attached to a swing arm under tension of a spring. Slight shortening of the spring might help but only as last resort.
Aug 12, 2014 | Speed Queen Washing Machines
The motor doesn't start; just hums.
I would have to agree that the motor is the problem, but before you replace it, check the bearing and blower fan to make sure they are in good shape. If the bearing is bad or the fan is blocked it could give you the same indication.
Jan 02, 2012 | Speed Queen AES28AWF Electric Dryer
Transporting a flat screen.....
Yes, it can be layed down. Just be sure it is cusiond well and does not slide around. Sliding could scratch the screen.
May 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Unbalanced Load Light
I don't know if this is a new washing machine or not, but I would recommend is getting a few small thin boards and making sure the machine is level. If this doesn't work there could be a bad sensor, but that doesn't seem like the case to me as moving the machine a little gets it to restart.
Apr 29, 2010 | Speed Queen AWS76NW Top Load Washer
How do I get that stupid screw out of the lint filter to clean the duct under it? My dryer is a AGS-28-AWF
I called Speed Queen direct & was told to use a 5/16" nut driver to remove the screw. Worked perfectly.
Dec 02, 2009 | Speed Queen Dryers
I have a maytag top load wash machine that has broke on me for the last time!!!! i want to get a speed queen to replace it. how do i go about getting a manual on a speed queen washer so i can see how they...
Click on Speed Queen above in blue...............front loaders would be nice. But ask the dealer where the filter is, what the codes mean, etc. These are all supposed to be secret - so their techs can come around to make more money..... No jokes its real.
Feb 26, 2009 | Speed Queen AWS52NW Top Load Washer
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Just stopped working
mine has a reset on the power head. alittle red button the back. if it is that old and worn out i would buy a refurbished one on like think i saw one for around $350. just search filter queen and u will find them
Aug 20, 2008 | Filter Queen Majestic Canister Vacuum
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
